Had my engine replaced what now.
Abby's Guy (01-07-2021)
Sorry :-)
2014 F-Type S
65K
Car over heated when driving the back roads. I pulled over checked the coolant topped put some in drove a little and started spewing steam. I had it towed and they replaced the Water Pump and hoses. it was still overheating,. they did a pressure test and found ot the Valves were warped? i believe that was the term.
so they replaced the engine.
with the new (used) engine that had 40K on it. it seems like the engine revs higher than the previous. it sounds a little rougher like its working harder than the previous engine.
2014 F-Type S
65K
Interesting that they replaced your engine (not under warranty, i assume); when my F-type overheated, the dealer rebuilt the damaged cylinder head. That was of course and engine out job, and i've had no issues since. Can't imagine a replacement engine was cheaper than rebuilding the head...
Burt Gummer (08-21-2020)
Mahjik (08-20-2020)
My story is almost identical to yours: 2014 V8 S. Overheat from cracked coolant pipe. Blown head gasket, hydraulic lock. I had 53k on the car, replaced w 40k used motor. No warranty. I'm too embarrassed to share what the repair bill was. The good news is, I'm still having a good ole time with the funnest car I've ever driven. If I run into hard luck I'd put the car on jackstands and sleep underneath it before I'd sell the thing.
The following 2 users liked this post by ferrral:
Abby's Guy (01-07-2021),
Munky (01-08-2021)
I would change the front and rear Diff fluids and possibly the transmission fluid. (just because these are expensive items to replace and fresh fluids are cheap insurance)
I would run several tanks of fuel system cleaner through it. (you don't know the history of the replacement engine or how long it sat out of the donor car)
I would change the engine oil very early and inspect it. (maybe at a thousand miles or so, just to get a base line and flush the donor engine incase it sat a long time out in elements)
Then.....I would just enjoy the car without pushing it to the limit until I had enough run time to have full confidence that everything was in proper working order.
Then..... Drive the way it was meant to be driven
MM
J444G (08-21-2020)
Yeah, they wouldn't approve the new one which is why i'm a little concerned. The Jaguar dealer would only install a new engine so i had to take it to a 2nd party jaguar repair shop.
i think i'm going to get this engine swap reviewed by the jaguar dealership to see if there are any problems that may arise while it's still covered under the warranty.
Sorry to read about your issues, could you add more context to your story. Was your extended warranty from jaguar or from another warranty company? JLR would not accept your warranty for a new replacement engine. You went to a independent Jaguar mechanic who replaced with a used engine but accepted your warranty. Now you want JLR to inspect your replacement engine and certify that all is well as it’s under warranty, from who? Please keep us updated on your warranty work. This could happen to any one of us. Thank you
Frank
Frank
I would make sure that everything associated with the engine cooling system was in excellent condition and would probably replace every hose in the system. (wasn't just your engine that got too hot, every part of the system was overheated)
MM
MM
Also, these coolant leaks and failures gives me nightmares.
How much longer has your warranty got left?
Personally, as others have said, I would monitor it for a while until you get confidence in it. Also your suggestion of getting Jaguar to check it over wouldn’t hurt.
If you sell it, I’m sorry to say, it’s going to show up on Carfax and will probably result in you having to sell for a lower than comparable price.
So just get out there, enjoy it and worry about the value when you have had ‘your money’s worth’ out of it!
PatJags156
07-02-2018 01:08 PM
