Has anybody tried fitting 355 P zero? with custom wheels
I know we have some folks with 305's in the rear, and I think there was a thread talking about someone going with 325's, but I haven't heard of anyone going as wide as 355. If you manage it, I'd be interested to see how it works out.
My GTR almost weighs the same and when I had 285 up front and 315on the rear the car would kick out the rear very quick and get sideways. Now im running 305 up front and 345 in the rear night and day difference. I know this is a different car but i would be interested in the results if you put skinnier tires on it and took it to the track or drag strip.
While this is absolutely true, i meant without significantly modifying the vehicle. To fit an extra 2 inches of tire you'd need fender flairs for sure.
Depends what you're looking for. A wider tire creates a wider lateral surface area which would help prevent the tire from losing grip while cornering. A skinnier or taller tire creates a wider longitudinal surface area which will help prevent smoky burnouts. All about what you're looking for a making the contact patch/sidewall stiffness work towards that.
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 11:32 AM
