Has anyone done a top engine clean
Old 02-25-2023, 08:50 AM
Carbuff2's Avatar
I don't like the idea of drilling a hole in the intake tube as I'm not sure how to properly plug it up again.
I just used a teardrop-shaped piece of aluminum duct tape (the same stuff that I use to assure that stick-on wheel weights don't fly off). I grab the 'tail' to peel it back when its time for the treatment, then re-apply.
Only needs replacement every 3 - 4 times.
Old 02-25-2023, 12:41 PM
jcb-memphis's Avatar
55k on car. OCI has been about 3-5k. JLR approved oils but I suspect that the key is not going to 15k for an oil change....use ravenol ecs with the lowest noack rating I could find for a 0w-20. May go to the EHS oil to get the new 6a timing chain protection (frequent changes may cover this anyway now with the older oil type...don't know). Also use top tier gas and bg44k every 2-3k miles. Cheap insurance.
Mechanic who had the engine apart to do the coolant pipes said there was no build up - nothing to do and likely at this rate nothing to do until at least 150 to 200k if ever. He was very impressed (has done a lot with GDI engines....so he knows the drill).
These engines are just really good in terms of carbon build-up compared to some other brands'.
burnibus84 (02-25-2023)
Len Apcar
04-25-2022 06:40 AM
92/93 XJS
03-04-2021 09:41 PM
BenFT
10-10-2020 05:41 PM
ITRacer98
01-22-2020 01:45 PM
manycars
11-14-2013 11:54 AM
Quick Reply: Has anyone done a top engine clean
