Has anyone had to replace the front caliper pin dust caps?
I was wondering if anyone has needed to or has purchased the caliper pin dust caps for the front calipers. I was searching them online and called a dealer but the one dealer claims it is sold as a kit. Just looking for the dust caps. I do see that BMW has very similar dust caps but without knowing diameter it is a shot in the dark.
Received 3,226 Likes
Probably not available from any JLR dealership as a separate item and maybe the same from all/most Jag parts retailers.
BUT many Beemers have verrry similar if not damn near identical front brakes to the Jag 380 mm ones so my WAG is the Beemer dust caps will be the same and fit just right. Also the base model 355 mm brakes also use a 9 mm hex driver for the caliper pins so I'm fairly sure they would use the same dust caps as well.
jamStypeR
17
05-26-2012 06:44 AM
