Hazard light switch
So the reason I revived this thread was due to the fact that I didn't connect anything to the OBD port; which is why I was going nuts trying to figure out a potential cause.
I'll check with my shop and confirm they hadn't either (didn't think they would by doing alignment work but you never know).
I had something similar in my first year of ownership. The first I knew about it was when InControl called to say the car just told them its battery was flat! The assistance guy came and got it jump started and I took it for a long drive and then put it on an overnight charge when I got home. Obviously the flat battery had cleared whatever was causing the drain and so far, 3 years on, I've had nothing like that happen again, not even after visiting dealers/independents who connected their gear to the OBD port. My independent cleared the fault codes, of which there were many since every module had reported the flat battery! I wonder if that happens when you do a disconnect reset, or if the modules don't have the power to raise a code in time.
Thanks for the response. It is a mess, I have the same hazard light issue and it has been in the shop going on week 7, they’ve replaced the SRS module and apparently that hasn’t solved it and they’re still trying to figure it out. Just being patient with it untill it’s figured out.
MJG
01-31-2013 05:55 AM
