Heated windshield washers?
I don't know, but I doubt it. The reservoir filler is at the rear on the trunk, and I don't see where the heat source would come from. There are more options for doing that in the engine compartment.
At any rate, windshield washer fluid does have anti-freeze properties, so it will flow just fine in frigid temps.
Received 2,263 Likes
On cars with more conventional washer jets (bonnet mounted), the heater element is in the Jets themselves, and is designed to prevent them from freezing up. The washer fluid will be at whatever temperature the area around the reservoir is, so probably not hot as such.
Does anyone remember the fun of pouring hot water on the washer jets to get them to thaw out? From memory, anything below freezing plus speeds of over 50 would cause it - even with neat screen wash...
DuhCar (11-22-2015)
DuhCar (11-22-2015)
Washer fluids here have a freezing point of -30C* or -40*C, so the jets freezing over would be unheard of.
Yes, I think there are people who put water in the reservoir, or dilute the fluid w/ water, which I wouldn't. I never had any freeze in my 10 years in Minnesota with proper wiper fluid.
Happens in Minnesota all the time (well, at least once every year or so). I remember having to drive my car several blocks in first gear because I couldn't move the gear shift lever.
sasie007
11-24-2015 07:15 AM
