Help with bumpy ride
Driving on highway today with my business partner in the passenger seat and after entering the highway we both felt a rhythmic bumpiness through the seat. Very damped though, like you were traveling over small smooth bumps a foot apart. No sensation of it in the steering wheel. Doing about 70 mph in dynamic and sport. Switched out of each and feeling seemed more pronounced. Lasted about 30 minutes. Started again towards the end of 90 mile trip. Same thing in reverse on the way back. Tires are overinflated by 3-5 lbs.- could that be causing it? 7k miles on the oem tires and the car since new. Wheel out of round? Bad roads? This an interstate toll road. I'm taking it to a local mechanic to have wheels and tires looked over as my dealer is 90 minutes away.
The feeling was like a car with bad shocks, but with very small vertical travel over consistently uneven road. Almost Nauseating feeling from the rhythmic bumpiness. Thoughts welcome.
Although unlikely as the cause of your issue; could it have been the pavement itself.. I have noticed that roads that have heavy truck traffic, just after the frost is out of the road, can sometimes produce a feeling something like you describe. Not potholes, but a regular undulation in the surface.
Lawrence
Lawrence
Burt Gummer (05-13-2017)
Lawrence
Lawrence
1. bent rear rim
2. out of balance rear wheel
3. road surface.
Mulmer's thinking on the road surface was also my first thought. This will happen most frequently on concrete surfaces with evenly spaced expansion joints. Try an asphalt paved state highway at speed before you waste money at the wheel/tire shop.
Those bumps you were feeling were probably occurring every 50 feet or so. At 70mph , you're covering over 100 feet/second
All 3 thoughts already provided are possible:
1. bent rear rim
3. road surface.
1. bent rear rim
3. road surface.
CRS
Great description. A pogo effect is a good way to describe this feeling with a very short amplitude! Is your car awd? It's the consistency of the movement/feeling that makes me suspect that it's a response coming from the car.
1. bent rear rim
3. road surface.
1. bent rear rim
3. road surface.
The original description said something about bumps a foot apart but not considering the speed, that description made me think of a cupped or scalloped rear tire which could be induced by 1 or 2 above or other suspension problem. Besides reconfirming on alternate surfaces, before you take it in, run your hand around the outside of the tire and you might be able to feel little cups in the tread.
I think you should apply some troubleshooting process. Eliminate one variable at a time. Start with the cheapest options. Go to the nearest Discount Tire or Tire Rack shop and ask them to balance your wheels. $40 later they will eliminate (or confirm) problems with tires/rims - bent, bubbled, unbalanced etc... If everything is fine you will still retain this problem, but at least your wheels will be in balance now, which wouldn't hurt in any case.
If you go with this problem to a dealer that's where they'll start as well, but at least they can eliminate wheels issues (at the dealer's rates it could be pricey)
1. bent rear rim
3. road surface.
1. bent rear rim
3. road surface.
As usual, you've echoed my thoughts to a "T".
Dave
Well, thanks for your input and comments everyone. The answer is no. 3, the road. As CRS, Unhinged and others surmised the road is causing the problem due to:
Concrete surface- edges of concrete curl upward at control joints with less than perfect curing after placement causing the mogul affect; Combined with f type wheel base at certain speed. Confirmed by variety of design professionals who also drive this stretch. One of my other business partners experiences this in his Toyota Tundra, but another partner in a Toyota Highlander does not. As pointed out speed is also a factor. I also wonder if the jags dynamic suspension makes This effect more prounounced. The curling of the concrete could be minimized with better curing. Really unsettling driving over this surface.
AJF (05-13-2017)
