Help with bumpy ride
They are not purposely over inflated. Well, they are from storage over the winter. I took most of the air out but checked them after the bumpy ride and where a bit over inflated. Since corrected. My car does display each tires pressure - it's a 2016.
AJF (05-14-2017)
AJF (05-15-2017)
Ooops! I do have actual tire pressure readings on my car. I couldn't figure out how to find it because the Vehicle Info option is greyed out unless the engine is not running but the ignition is turned on . Just bought the car a few weeks ago and still learning ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
On my other you could check while driving, which IMO is a better way to go. Such as in the case of this thread, where the car doesn't feel quite right, you can rule out tire pressures while driving.
