Help! F-Type ABS, ESC, gearbox etc faults while starting up
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Hi guys! I just found this forum as I am a very recent (and happy) F-Type owner. My car is a 2013 F-Type S Cabrio with ca 40.000 km (25.000 miles) on the clock. I have experienced some issues this and last week.. The car is going in for a check next week, but would love to get some reasons to why this is happening, as it is stressing me a little:
First problem with the car was that on Wednesday the 8th of May, suddenly when driving, the center screen just shut down, and restarted a few minutes later. This happened twice on the same day, and haven't seen this problem ever since. On the 9th, I had the car in for a transmission fluid change and the bigger 12V battery was replaced at the same time (I didn't know at this point that the car has two 12V batteries). The next problem (which still occurs) came on the 12th. I started the car, opened the roof, and it says "gearbox fault", not allowing me to switch into gear. Shutting down and locking the car clears the issue. This has been going on once in a while the whole week, clearing itself by restarting and locking the car. In addition, sometimes when opening the roof, it glitches ca 70% open, and closes slower, or when re-pressing the button, then it continues opening properly. No problems with the closing of the roof. I'm mentioning this just in case it has some relation to the other issues. On the 16th and 17th I have started to experience some other faults which occur a few minutes in to the drive (also clearing with restarting and locking the car): The car gives yellow triangles on the dash for: Traction control fault, ABS fault Emergency brake assist fault, parking brake fault, Dynamic mode not available.
I have done some research on this and possible explanations have been;
- 12V battery fault
- Alternator fault (tested, works)
- ABS or wheel speed sensor fault
- Bad earth points
Does someone have similar experiences? Should it be a simple fix, where to start?
Many thanks in advance!
Best,
Kasper
- 12V battery fault
- Bad earth points
Best,
Kasper
The first two things to check are as follows:
1. Put a battery charger or battery tender on the battery and fully charge it. Yes you just got a new battery, but there is no guarantee that new battery came fully charged. F-Types are very sensitive to battery issues.
2. Make sure after you turn the car off that the warning triangle on the dash goes out after ten minutes. If it does not the battery is being drained and you need to disconnect one of the battery cables for a minute to reset the system.
Good luck!
Good luck!
The following 2 users liked this post by cpq100:
Carbuff2 (05-19-2024),
KasperRautalinko (05-19-2024)
Exactly right on both points!
Exactly right on both points! The secondary battery only controls the irritating Stop/start system, no other function.
This is not a “Jaguar thing”; every luxury car maker (Aston Martin, Bugatti, Rolls Royce, Bentley, Maserati, Jaguar, BMW, Audi, Ferrari, Lamborghini….the list is very long) sells the CTEK battery maintainer under its own label, and for the reason stated above: hungry electronic modules.
Received 3,226 Likes
Just disconnect the negative battery lead for 20 seconds or so then reconnect it.
Easiest way is to unbolt the earth lead running off the negative terminal from where it bolts to the floor of the boot/trunk, 13 mm nut IIRC.
Now that the battery is fully charged try doing a systems reset.
But DO NOT close the trunk/boot/hatch after you have done so!
BuggDomi (05-21-2024)
yeah I found out the tough way when my battery died on me the other day that there is no way into the trunk with the dead battery
Hey,
Quick update with some good and bad news:
All the ESC, TC, ABS lights where caused by a faulty ABS sensor in the rear. That got replaced alongside the other 12V battery and now these work. However, the "gearbox fault" problem still persists. The Jaguar mechanincs (independent specialists) tried downloading a new gearbox software which did not solve the problem. The fault codes are related to one of the CAN buses. They are gonna further investigate the issue during the end of the week. Any thoughts?
Thanks!
Thanks!
Carbuff2 (06-10-2024)
pennstater
03-21-2022 11:26 AM
Nelsters
04-18-2012 04:51 PM
