help. I put on 305/35/20 from 305/30/20 and now sensors are going crazy.
I put on a set of 305/35/20 in place of the factory 305/30/20. I used the factory rims and now I have just about every sensor going off. TPMS, ABS, parking break and also I cant open the trunk using the button on kfob or on trunk. Any help please. I want to keep the 35's if at all possible
Received 3,259 Likes
One of these: http://indianautosblog.com/wp-conten..._4847-Copy.jpg
Same motor and tune as the F-Type R.
This doesn't explain your trunk problem though, unless Jaguar has some weird logic about that in the software.
Also, see here for a reasonably good review of the XKRS-GT: https://www.autocar.co.uk/car-review...s-gt-2012-2014
Nup, the XKRS-GT is RWD only, and I believe all XKs are RWD only.
Doh! I just remembered you don't have an F-Type. You definitely will need to check clearance.
Ok this is what I did. I put a 255/40/20 on the front and took for a spin and no sensor issue. To recap I put a 305/35/20 drag radial on the factory 12/20 wheels. I left the front factory tires on 255/35/20. This made a 5% circumference difference front to back using a tire comparison chart. The factory circumference difference was .7%. I then put the 255/40/20 on front using the factory 9/20 wheels. This circumference difference is 1.4%. Thx for the opinions / ideas. I couldn't have done it without the help.
fredom dsm (07-05-2023)
