HELP! Info display going crazy
CRS
Your car is still under warranty, so take it back and they should replce the unit.
If it were me, I would remove the head unit, and I bet it's the ribbon cable and very fine pitch connector that connects the PCB to the screen has a partial connection.
Just a wiggle first would most probably suffice, if not delve deeper.
Dealers will just chuck the old unit in the skip I guess...cheaper than fault finding these days!
Disconnecting the battery and touching the leads together discharges any current remaining in modules (capacitors) and in theory resets, the screen in this case. Jaguar recommends this on a few of their TSB's. If it doesn't work, no harm done. For those in Europe, you might want to save your radio code so you can re-enter it if needed. No code required here in the U.S.
usgpru27 (01-01-2019)
Magna1969
03-16-2018 09:10 AM
draguarxkrsgt
04-27-2017 03:55 PM
lozzer65
04-15-2014 05:59 PM
