Help with key fob
Sometimes it locks and unlocks, sometimes it doesn’t.
sometimes I can’t lock or unlock the door with the handle outside.
the car always starts however.
ive replaced the battery and it didn’t help, any suggestions?
Update: I revived the car back from the dealership, there was a KTM update. It now works fine
Received 3,209 Likes
Take the battery out and use some needle nosed pliers or tweezers to squeeze the two side tangs a bit closer together and the top tang a bit lower/tighter, then see how you go.
Unlikely to work though but as it's free it's worth a try.
More likely the car has a dodgy door lock module.
