Help Please
Help Please
I’m wanting to buy a 2014 type F. The car seems perfect with 14,000 miles. But there is where in tear on the steering wheel under their control buttons on both sides that doesn’t look normal. Is that a issue with these cars and should I be worried about it?
Should I buy a car with 14,000 miles on it with a steering wheel that looks like this? 2014 type F
It looks very odd and not typical. (My MY14 is a 'vert, has more like 20k miles, and shows no signs of wear.)
It may be just cosmetic, but I'd double check the history with Carfax and the servicing dealer to make sure there wasn't an airbag deployed (and whatever else would have happened around that).
MidLifeinTN (05-12-2019)
What you see COULD be an issue with the 'soft-touch' black surfaces that was common on the first few years of production.
For sure, long fingernails on a hot interior could have scratched the button surfaces. Or, a diamond ring....
I'd look up the cost of replacement (if it's a Jag dealer, make them do it as a condition of sale). If the rest of the car is otherwise 'perfect' (have you checked the wear on the INSIDE of the rear tires?) don't let this cosmetic issue hold you back.
The buttons average $140 a side + install labor. Items 7 & 8
https://parts.ftmyersjaguar.com/v-20...wheel-and-trim
How are the rest of the black surfaces (and the start button)? Door panels, side vents, etc. The steering wheel cover isn't listed on the page I linked, but there are aftermarket covers available IIRC.
I was just going to say it looks like chemical damage, not mechanical. If the dealership would replace it, I wouldn't necessary sneeze at the thought of buying this car.
sinker123
40
06-25-2018 01:22 PM
cbryantjr85
10-21-2016 03:46 PM
JimC64
11-22-2012 07:26 AM
driftr319
07-29-2011 12:30 PM
