Help! What is this line and where does it go?
I managed to get a vacuum leak on the air chamber assembly (part # C2Z30725) and noticed that it has a nozzle looking thing connected to nothing and a hose further down also not connected to anything.
After much digging, I found out that the nozzle line is also part of the air chamber assembly (part # AJ812350) so thats resolved I hope (just ordered both parts). Now the hose further down is what I'm confused on.. The previous owner did not disclose that it didn't have these lines being connected to anything sadly.
If anyone has any insight or can share a picture of where this hose line with blue/green text at the back near the AC port that would really help a ton!
I believe what you are looking at in picture #1 is part of the symposer assembly that connects the tuning valve (item 7 below) to the actuator on the air box. It should loop from here down to a port on the bottom of pneumatic valve (item 9). It looks like the actual hard vacuum line has broken off.
Cwis (04-13-2022)
I'd say that the symposer is incapable of any "enhancement," but I'm perhaps the leading opponent of it on this forum. I continue to plot its complete removal from my car, but disabled it no longer offends me physically (only spiritually). Nevertheless, that line has an individual number in the diagram so should be available as a spare part. It's a molded plastic line with rubber fittings, so shouldn't be prohibitively expensive.
Cwis (04-13-2022)
I honestly can't tell a difference in sound, so maybe no enhancement.. but could be because all I hear instead is my vacuum leak on part #11 LOL
scottjh9
11-28-2018 10:48 PM
Hollywood XJR
11-12-2018 07:28 AM
