Have managed just now to have my audio supplier fess up with regards to where it comes from as he says before long it'll be common knowledge anyway. https://ewaygps.com/product/optical-...t-description/
Remember you saw it here first! Those Chinese huh, who knows what they know? Reminds me of an 80's tune
All, DED instructions are here. If you download on android a BT Controller App and you can't connect to your DED by Bluetooth then it is the wrong App so PM me for the correct one with Whatsapp number as I only have it on there. More info on the DED can be found here:
Dale, I'm about to do the same to my 2021 F-type. What was your experience with this box? Was it worth it? Did you try to use the line outputs of the factory amp first? I've got a couple of DSP amps but they don't have an optical input so I'll have to use a digital to analog converter between the interface box and my amps. I'm debating if it will be worth it to have 5 different devices to get a quality signal.
I can say it was very worth it for me because I wanted a pure unprocessed signal from the jaguar IAM. Also the digital decoder has digital coax as another signal output option. System sounded ok before and maybe acceptable for alot of people but if you want the best you can get, you need to start with a pure unprocessed signal before your DSP. If neither the optical or digital coax are able to be utilized, a module such as a topping D10 between the Daead and your DSP is an excellent affordable interface to get you rca outputs after the DED.
Topping D10s Mini USB DAC CSS XMOS XU208 ES9038Q2M OPA2134 Audio Amplifier Decoder Black https://a.co/d/7p8YzZg
