Hex Size for Removing the Steering Wheel?
Socket Size for Removing the Steering Wheel?
Hi guys,
I've seen the official instructions for removing a steering wheel on the F-type and done it on some BMW's in the past. But before I start the job, I can only see reference to a special Jaguar tool for the job, but what's the bolt head size? BMW's were normally 16mm, but Jag looks bigger and wondering if it's a weird size.
Graeme
Graeme
Received 3,226 Likes
You don't need a special tool to undo the main steering wheel bolt, it's just a standard hex headed bolt.
Which means one of a normal set of hex sockets has gotta fit, my guess is 16, 17, 18 or 19 mm. My money is on 17 mm.
There is a diagram of the steering wheel components in the Workshop Manual showing the bolt but it doesn't say anywhere what size it is.
And one more tip - don't disconnect the battery until you have unclipped (but not removed) the steering wheel air bag, as you need to turn the wheel 90 degrees one way first then back 180 degrees the other way to do the unclipping. This unclipping is what the "special tool" is for but apparently (I have never done it) you can do so with a small flat blade screwdriver.
Started the job, air bag removed fairly easy, but a little unsure how to remove these connectors and they look fragile. On the older Jags the orange tabs seem to slide back, then pull the connector off upwards pressing in the side tabs, but these are different.
Jaguar manual says "Release the locking tang and disconnect the electrical connector"
For info, the bolt size appears to be either 21mm or 13/16".
Yeah that's right. I didn't get pictures, but this video shows you everything you need -
Also, as per the advice above - "And one more tip - don't disconnect the battery until you have unclipped (but not removed) the steering wheel air bag, as you need to turn the wheel 90 degrees one way first then back 180 degrees the other way to do the unclipping. "
SS4PK (04-30-2020)
