High (damaging) RPM At Start Up
UPDATE: Started the car this morning...business as usual. Nothing quiet about it. Loving every minute of it Jerry.
burnie (04-29-2015)
To build on Jay's response a bit, it is not the extended 1400 rpm warm-up that is being referred to, but rather the instantaneous automatic throttle blip to 2500-3000 rpm with open baffles that occurs immediately upon start-up.
burnie (04-29-2015)
Mine too. Not questioning your personal experience - your You Tube clip is proof it worked for you - or DJS's, but based on mine, put me in the debunked camp.
#28
I seem to recall one occasion where I experienced that when playing with the car shortly after delivery. I rarely do this, but I think if you re-start the car within a few minutes after shutting it down, that sometimes happens. I don't think it has anything to do with hitting the start button first with your foot off the brake.
When that theory was advanced here some time back, I tried it numerous times on a cold start, and it never made a difference.
Edit - I popped into the office this morning and just tested this again when starting to head home. Same result. The car was as loud for the initial when using the technique described and quieter on a subsequent restart.
thanks
#31
#32
There are two issues being discussed in this thread. First, is the start up blip where the engine immediately runs up to probably 2500 rpms and throttles back very quickly. After that, it has a faster idle for a short period of time as I think you're describing.
It's OK to put it in gear and go during the fast idle. Just putting it in gear will throttle it back.
#33
Can you do it before then? Yes and it likely won't be a problem. However, I tend to stay with the 30-45 second rule just to be easy on my cars.
RickyJay52 (04-29-2015)
#34
Burnie
#35
#36
I don't remember what the update code was, there was thread about here and a few members weren’t too happy with the update and I was one them initially. The only reason why I found out about the update because I started noticing the car was reverting to normal mode even if it’s in dynamic mode when I turned the car off and it wasn’t like that before I brought it to the dealer to be serviced, if the car was on dynamic mode when I turned it off it would still be in dynamic when I started for at least a couple of hours later. It might even be longer I can’t remember, it’s whenever the car went to sleep mode, i think thats when it resets back the default normal mode. It makes sense if they’re trying to lower the db levels at start up. when it’s in normal mode the exhaust valves closed and is not as loud as when it’s in dynamic with active exhaust valves open. Apparently JLR felt there was enough demand/complaints and they needed to do something about it and if i recall correctly it started in europe and then came to the North America.
You should check with your JLR service about getting the update if it hasn't been done and maybe it will be quiet enough for you and your neighbors and everyone’s happy and it would be one less problem you have about your ftype. I think I speak for everyone on this but most of the people that get into an FType knows about the much louder than the normal exhaust whether its a v6 or an 8 Ftypes are known for its exhaust notes and as you put it “the dramatics” its what gives the car character, its part of the design it is what it is and you either accept it with all its quirks and or you don’t. It doesn't matter what anyone else or what the neighbors think or feel about your car and at the end of the day the only thing that should matter is how you feel when you’re driving the car. Are you excited and does the car make feel more alive and want to drive the car like you stole it and the loud exhaust does draw attention, good and bad but it comes with the territory when you own and drive an FType and if you can’t accept and deal with it, maybe it’s time to consider driving something else maybe something that doesn’t draw attention and blends with the crowd and something quieter perhaps a Prius or a Nissan Leaf .
#37
... if the car was on dynamic mode when I turned it off it would still be in dynamic when I started for at least a couple of hours later. It might even be longer I can’t remember, it’s whenever the car went to sleep mode, i think thats when it resets back the default normal mode.
#38
