Hood louvre replacement
Old 02-01-2017, 09:51 AM
NSY's Avatar
NSY
NSY is offline
Great advice. Thank you so much.
Old 02-01-2017, 03:40 PM
OzXFR's Avatar
Received 3,226 Likes on 2,380 Posts
Mina appear to have honeycomb style in stainless, for both shapes of hood vent, see here:
Jaguar - F-Type - F-Type Exterior Items - Mina Gallery Inc
Not exactly cheap mind you!
Old 02-01-2017, 04:18 PM
NSY's Avatar
NSY
NSY is offline
Thank you. Will call. Looked like only the AWD but will check.
Old 09-25-2018, 04:00 PM
bryklug2001's Avatar
Originally Posted by MI-FType
Here is a picture of them.
Lowest dealer price I have seen is $240 for the set. I am asking $80 and will pay the shipping.
Do you still have these available?
THX
Old 09-25-2018, 06:37 PM
MI-FType's Avatar
THX
You are in luck.... yes, I do still have them tucked away.
These fit MY14-current, non AWD spec.
Old 09-25-2018, 09:11 PM
lizzardo's Avatar
The mesh vents were, to my knowledge, only ever found in black.
I changed my standard mesh vents for "bright" (call it chrome if you want) because the mesh was allowing the sun to bleach the parts underneath. It was just the engine cover but I wanted to remove that. I didn't want any plastic hose fittings to become embrittled and crack.
I'm not normally a chrome kind of guy, but on a very dark car, hood vents and side vents as the only bright accents is acceptable (wheels are silver or brake dust color depending on time since last cleaning). The mesh probably vents more heat, but I could toss the cover into storage with impunity with the others. I got one on eBay, matched it with one from the dealer. Yeah, I paid too much. In the Grand Scheme, I've got bigger issues over which to lose sleep. Like work. They're busting my chops, and the F-Type is my sanctuary.
Old 09-25-2018, 09:52 PM
Suaro's Avatar
I thought the black honeycomb bonnet vents looked cheap and so replaced them with the chrome vents which match the side vents. A much more coordinated put together look in my estimation. On my silver car they make for a nice highlight instead of the cheap black honeycombs which look like another JLR shortcut.
  #28
Old 09-25-2018, 10:08 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
The black honeycomb looks good on a dark car, but indeed looks cheap on a very light car.
Old 07-23-2019, 09:57 AM
Robert Lapienski's Avatar
Are these louvres still available?
  #30
Old 07-23-2019, 12:36 PM
rbsj's Avatar
Originally Posted by Rjscharer
I purchased silver wire mesh inserts from Mina Gallery. I think they look
terrific on my AWD S.
If anyone is interested you can see both the Mina Gallery mesh hood and side vents on a Polaris White car in my post earlier today by enlarging the After picture of the car:
https://www.jaguarforums.com/forum/f...weight-220867/
  #31
Old 04-09-2020, 09:19 AM
Deogee's Avatar
[QUOTE=MI-FType;1612350]Here is a picture of them.
Are these still available?
  #32
Old 09-04-2020, 09:56 AM
Taylorguy74's Avatar
Old thread rehash - are the Mina vents the all black powdercoat option on your pic?
  #33
Old 09-04-2020, 09:59 AM
gg2684's Avatar
I have rhodium silver vents to match the car (2016) and planning to convert numerous exterior parts to Koshi carbon fiber and want to get carbon vets - is the dealer the only option for this?
  #34
Old 09-04-2020, 01:42 PM
rbsj's Avatar
If you go to the Mina Gallery web site it is pretty obvious which of the two hood vents is on my car. I have done nothing to them except remove the "Supercharged" plate. I have attached a close up of how they look on the car currently below.
Taylorguy74 (09-04-2020)
  #35
Old 09-05-2020, 08:28 AM
rbsj's Avatar
One additional thing about going with what I will call "real" hood vents (i.e., a hood vent that has enough open area to actually do some venting of the engine compartment). I was a bit concerned originally about water getting into the engine compartment while driving and or sitting at stop lights. The first few times I got caught in some big storms I was a bit wigged out and when home would pull into the garage, pop the latch on the bonnet to immediately inspect the damage. Only to find not a single drop of water or even any sign of wetness in the engine compartment. After doing this several times I concluded that the engine compartment in these cars are so hot when at temperature that any water entering is boiled off as steam when encountering the engine components almost immediately. Now, I am lucky that my car is garaged at home and in an under building garage at work so it hardly ever sits outside when cool, but I thought I would share this for those of you that may have the same concerns about using more open vents.
  #36
Old 09-05-2020, 11:20 AM
scm's Avatar
scm
scm is online now
Received 1,482 Likes on 1,122 Posts
The F-Type is my third Jag with hood vents (a couple of XKRs previously) and they've sat on my drive under inches of snow without problems in the past, so I certainly wouldn't worry about it.
  #37
Old 12-01-2020, 08:05 PM
DesignConfig's Avatar
just what I am looking for, pity this post is 2 years old...
  #38
Old 02-06-2021, 08:42 AM
koolkat's Avatar
rbsj, how difficult was it to remove the supercharged tag and at some point could it be reattached???
Looking at ordering a set for mine from Mina Gallery.
  #39
Old 02-06-2021, 09:58 AM
rbsj's Avatar
Piece of cake. Two screws welded to the back of the Supercharger plate hold it onto the wire mesh. Can easily be removed or replaced without any blemish.
  #40
Old 02-06-2021, 12:49 PM
koolkat's Avatar
Sweet, thanks I'm ordering now!
Quick Reply: Hood louvre replacement
