Hot CTEK
Hot CTEK
I recently plugged my F-Type into a CTEK in an attempt to battery drain during my upcoming cruise. After about 1 hr. the CTEK was so hot it was difficult to hold. I have the contacts secured to the battery positive terminal, and the negative side attached to the battery hold down post.
Is this normal??
Is this normal??
I don't think there's a mode for maintain - once the CTEK has fully charged the battery it goes into "maintain" mode which involves monitoring the state of charge and occasionally top up as necessary.
My F-Type connected to the CTEK, always...months at a time. It does not get hot - certainly not after the battery has been brought to full charge.
This is how the CTEK is connected : the negative lead (black) to any bolt on the floor of the trunk, and the positive lead (red) to any of the connecting spots in the black box that sits on the floor near the battery. Your 2020 car may have a different electrical box but the same principle apples. In other words, the connection is not made directly to the battery.
Sorry to change the subject but it seems like the CTEK series of battery maintainer is by far the most popular one used by many car folks. I have used others historically and currently use a really reasonably priced Genius 1 which has performed flawlessly. Is there something about the CTEK that makes it a better or safer option? I am not sure what I would be gaining by spending five times as much. Thanks!
Is this normal??
Is this normal??
1: Battery was really low and needed a good charge.
2: There is a load on the battery (and hence the CTEK too). Is something on in the car?
I don't think its a short because the CTEK units shut down in the event of a dead short. At least mine does.
https://howtune.com/articles/548-ins...-jaguar-f-type
Also, when you first plug in the CTEK you configure it for an automobile battery and an AGM type battery. See step # 8 in the link. Once you have done that the unit will remember the settings.
The CTEK has circuitry to evaluate the state of the charge of your battery. When you first plug it it, it will top off the charge and then go into the "trickle charge" or maintain mode.
There are other chargers on the market, I have one from Harbor Freight that I think was around $30. It works if I want to top off the charge on my Mazda CX 5 or the battery in my generator but it takes 10-12 hours and you sure don't want to leave it plugged in once it reaches a full charge. I didn't mind spending the money for the CTEK, it is a much more sophisticated piece of electronics.
I had not heard of the NOCO Genius 1 prior to buying my CTEK. It does have almost 35,000 4.5 star ratings on Amazon so there are plenty of satisfied owners. I compared the specs to the CTEK MXS 5.0 which is what most of us are using.
Genius 1 Charging Current 1 Amp CTEK Charging Current 4.3 Amps
Genius 1 Warranty 3 Years CTEK Warranty 5 Years Note: They both are manufactured in China
Genius 1 Battery Capacity 30 Ah CTEK battery Capacity 110 Ah
The CTEK seems to be the Gold Standard for such devices but is it worth more than 3X the price of the Genius 1 ? From the specs it seems like it will charge batteries faster and handle batteries with a higher Ah rating and has a longer warranty. At least the Genius 1 has a 3 year warranty instead of some pessimistic 1 year warranty so it must be a quality unit, it's just built to a price point as far as the ratings.
The Genius 5 looks like a closer comparison to the CTEK MXS 5.0 and at $69.95 is still less expensive than the CTEK. That one might be worth considering too.
My ctek gets quite warm when attached to the "correct" spot in front. In theory it should not matter where the charger is attached - the ctek I am using is the newest, smartest units....I had an older one that may not have been as "smart"....
Anyway, my guess is one person's "hot" is another person's "quite warm"....
jb
jb
Is this normal??
Is this normal??
Thanks for the information!
Yes, that thick red lead goes directly to the battery; your question is a valid one. I think the answer is that if the charger’s connections are made directly to the battery, you are eliminating the quite sophisticated charging monitoring in the car’s electrical system…and the necessity of using the car’s monitoring system is precisely why that battery + cable is attached to that box.
