How about this noise: when idling, manual transmission R-Dynamic V6 2018
I've noticed that there's a strange noise that sounds like a high pitched churning. It seems to be worse at the cold start of the vehicle and when the car is in neutral/idling. In the videos at the link below, you can hear the noise in all three videos -- in the longest video (just over 30 seconds) you'll hear the churning noise, then I move forward (in gear) and the noise seems to stop (or maybe it's just overpowered by the sound of the engine) but then the noise comes back again when I go back into neutral.
Any thoughts -- is this normal??
https://drive.google.com/open?id=1QS...p4BBkE4tkcyjOT
If the throw-out bearing is bad, it would only be noisy when the clutch pedal is depressed. If it makes noise only when in neutral and the pedal is released, then it's probably a bad bearing on the tranny input shaft.
flynnaaron
05-04-2024 07:14 PM
Wolfy
01-11-2020 01:56 PM
carzaddict
11-08-2016 04:45 PM
bluh5d
12-02-2010 10:37 PM
