How to clean the radiator above the splitter
So I posted about my trip to the mountains. https://www.jaguarforums.com/forum/f...dragon-253533/
Cleaning the car I found Lots of leaves lower radiator. Is that an oil cooler or a transmission cooler?
Anyhow, how do you clean this? It appears to close in on itself leaving no way for debris to get out. Do you have to just break ot the vacuum cleaner?
The first 2 pics are for location and the 3rd is all the crap I pulled out of it.
Thanks for the help
Thanks for the help
McPhaul (11-18-2021)
Best, safest, and most correct approach (and time consuming) is to remove the front bumper/facia, and you will have full access to clean it properly. Otherwise, you can likely get the larger stuff out with a narrow vacuum device.
Bumper removal is about a 20-30 minute task...Not that bad really. I think there are lots of good tips on removal on the Project 7 Grille Threads that I and others posted in.
Good luck...
DC
Good luck...
DC
Good luck...
DC
Good luck...
DC
brndst
02-24-2014 02:52 AM
