How to disconnect and reconnect the battery/reset the battery module
I appear to have the same issue as many (e.g, forum threads "battery drained due to OBD port", "Dead Battery ::FURIOUS::", etc.) who have returned from a vehicle service and found the Low Battery warning the next day on their dash board (and observed the door lock LEDs and hazard light remaining on for hours after parking and locking their car). The solution appears to be resetting the battery module by disconnecting and reconnecting the battery.
The trouble is: how exactly do I go about disconnecting and reconnecting the battery?
After removing the trunk liner and opening the power connector box, here's what I see in my F-Type 2017:
F-Type 2017 with trunk liner removed and connector box opened, seen from top
Received 3,218 Likes
See the short thick black cable bolted to the floor, LHS and just below middle of the pic?
That's the battery earth lead.
All you need to do is disconnect that lead for a while (and make sure the end stays away from any metal area).
From memory it's a 14 mm nut to undo, 2 minute job tops.
The following 4 users liked this post by OzXFR:
dwmilton (06-23-2020),
JacksonvilleJag (06-12-2020),
Misujerr (01-07-2018),
safetyfirst (01-07-2018)
Correction: the hazard light turns off, too, it just takes a little longer.
As mentioned, date on dash was reset, windows needed to be reset (wouldn't go up all the way after letting go off window button; reset is done by lowering and raising each window 5 times (documented in owner's manual)); Bluetooth devices were retained.
The following 2 users liked this post by Unhingd:
Positive vs negative??
Is there a reason you recommend disconnecting the positive over the negative?? I would think the sparking would not occur if the negative cable was removed.
And you are correct, little or no sparking disconnecting and/or reconnecting that lead but potentially lots of sparking from disconnecting and/or reconnecting the positive battery lead.
JacksonvilleJag (10-07-2020)
The following 2 users liked this post by JacksonvilleJag:
jcb-memphis (03-28-2022),
The_White_Pantera (05-16-2023)
The following 3 users liked this post by Unhingd:
The following 2 users liked this post by Dogbreath!:
JacksonvilleJag (10-07-2020),
Black15FTR (10-07-2020)
The following 2 users liked this post by fujicoupe:
JacksonvilleJag (10-08-2020),
