I have the 770W system and mine has always displayed the audio details between the tacho and the speedo.
Maybe there is a setting somewhere, I'll nip out to the garage and have a play and report back, watch this space!
Ok, I've had a fiddle, and I couldn't find any setting for this either through the central display set up (press the Menu/OK button on the LHS of the steering wheel a couple of times) or through the Audio settings on the main console.
But while I was fiddling with the central display set up and running through all the options, then turning ignition and/or audio off then on, I somehow managed to turn the audio details display off!
Then a single press of the Menu/OK button turned it back on again.
So try simply pressing the Menu/OK button once, you never know it might turn the audio details display on for you!
I've got the newer display, and it's configurable via the display settings: Audio, trip information, or logo. The settings are accessible via the left steering wheel buttons. I wasn't aware that the earlier versions were not configurable, but if it's not there, it's not there
I took delivery of my car in January 2014 and it has the audio information displayed, there are no options to enable it or disable it in either the touchscreen or the instrument cluster menu options. Its just on all the time (couldn't find a way to switch it off).
That is strange because I have exactly the same graphic display as you and can't get there audio information.
Ok I found a way to make it disappear... by pressing the mute button on the volume control - but then nothing is playing at that point anyway!
What audio source are you listening to - maybe its specific to certain sources, eg radio / sat radio only??
It doesn't matter what source I use...mostly I am using a bluetooth connection with my iPhone but even if I use FM radio or DAB radio...I still can't get it there.
I will ask Jaguar dealer if there wasn't some sw upgrade, because is it strange.
