How do I clear ''Service Required'' and Torque Pro IAT2 Q
Wondered if anyone had any joy clearing a ''Service Required'' message using Torque Pro as it doesn't seem to flag as a fault code in the app?
Also at the weekend I wanted to take some IAT2 temperature readings for another thread, however Torque Pro is reading 80C at cold! I have checked the .csv PID file and am 100% sure that it's not the imperial one, and that my IAT2 sensor is good...any other plausible reason that this is not within a gnat's crotchet of the IAT temp?
It's quite possible that I'm doing something daft, however other members seem to be getting reasonable readings?
The following 5 users liked this post by scm:
Carbuff2 (05-13-2019),
Itismejoshy (05-13-2019),
Queen and Country (08-22-2019),
Tel (05-14-2019),
WJV (05-14-2019)
I have 'torque pro' as an app also, but I use it to make roadmovie's with the dials in the video. Sofar I didn't dare to plug the OBD2 plug into the F-Type, as I read several threads about error
codes that then are generated and JLR voids your guarantee.. ??
I contacted my dealer and JLR to provide me with a type/make of OBD2 plug [ ISO standard, they'te obliged to comply], which they approve of, and if I use that no effect will be linked to my
guarantee..
Its still pending and we're leaving next week. But as I understand you are already pluggin OBD2 plugs in with BT/WiFi links ???
guarantee..
Spot on...well done that man...just a bit confused when you said bonnet, I could only find the hood ;-)
Will this work for a 2010 Jaguar XK? I'm tired of getting an oil change every 750 miles just to get the service reset. Thanks. Doesn't seem to work for my 2010 XK. Am I doing something wrong or is this reset just for the F Type? Thanks all.
Received 3,226 Likes
There is/was a completely different procedure for the 2008 - 2015 XF which I reckon is a good chance of working on your XK, attached.
But it's tricky, you have around two seconds to complete steps 1 to 5!
You need to memorise and practice the steps and eventually you will succeed.
bocatrip (08-21-2019)
Almost zero chance it will work on a 2010 XK.
scm (08-22-2019)
Michael Star
23
04-18-2012 01:20 PM
