How Many Jaguar References In The Cockpit?
It's evident that JLR wants us to know we are driving a Jaguar. That said, if you are driving at or over 72 mph (first hint) with the dash vents in the upright position (second hint) how many Jaguar references would you see?
BTW, you should answer before you go out to the car
(A) 4
(B) 7
(C) 9
(D) 11
The definitions of references is, the written word Jaguar, as well as the Leaper.
(A) 4
(B) 7
(C) 9
(D) 11
(A) 4
(B) 7
(C) 9
(D) 11
(A) 4
(B) 7
(C) 9
(D) 11
I believe the answer the OP had concluded was 9. But you missed 6 rather obvious ones... I'm up to 15, and I counted in the dark. I bet I can come up with more at daybreak. In fact I know I can add two more for a total of 17, and if Growlers count as references, I'm up to 19.
4 Jaguars on 4 HVAC vent sliders
4 Jaguars embossed inside each window
1 leaper on center steering wheel
1 Jaguar on dash display
1 Jaguar on center display
1 Jaguar on spoiler above 60 (convertible)
1 leaper on spoiler above 60
1 leaper on center screen if selected as a screen saver in lieu of having menu up
1 grille growler visible as reflected off some vehicles in front when queued up
Saw 15 this morning.
clue me in-I have a 2016
I see only the leaper on the steering wheel and the one in the mirror with the jag name as well (does that count as 2?)
once the engine is on the one in the info screen and dash pod disappear. Couldn't find one on the vents maybe I need to put on my reading specs? There are a few r's but they don't count
I am now up to 30 and still counting
the OP's original 9...
1 Jaguar at top of dash display
1 Jaguar at top of center Navigation Screen display
1 Jaguar on spoiler (up in maintenance mode while parked)
1 Leaper on spoiler (up in maintenance mode while parked)
PLUS...
6 Jaguars embossed on each window (4 on vert)
2 Jaguars on floor mats
2 Jaguars on wheel caps (viewed when parked adjacent to plate glass window)
2 Growlers on wheel caps (viewed when parked adjacent to plate glass window)
Late Add:
2 Jaguars on Seatbelt labels where end of each belt is tethered to floorboard.
2 Leapers on Seatbelt labels where end of each belt is tethered to floorboard.
1 Jaguar on branded USB dongle inserted into USB port in console (optional)
1 Leaper on branded USB dongle inserted into USB port in console (optional)
1 Jaguar on key fob (left on console instead of in pocket)
(2 if I hold the key fob up to the rear view mirror)
1 Jaguar on grille badge (visible as reflected off some other vehicle or object in front)
1 Growler on grille badge (visible as reflected off some other vehicle or object in front)
Foosh, I know you knew this one on your list is an either/or thing, not both visible at the same time.
"1 leaper on center screen if selected as a screen saver in lieu of having menu up" If the Screen Saver is up, the Jaguar at the top of the normal menu is not.
Wait, need to go open the glove box...
