How many miles out of the rear stock Pirelli's?
Unlike so many others around here, I'm reasonably satisfied with PZeros. Mine are showing zero signs of wear at 6K, and I think the warm weather handling is superb.
You do have to seriously dial back your driving style in cold weather, which any sane person should be doing, and they do OK. However, I absolutely stay away from frozen precipitation with them and don't drive the car when that is likely.
Found out this evening that since the 19 inch wheels have a 9.5 inch width, the safe size to increase to would be 285/35/19s, up from the stock 275s. Going to up to 295 will push the sidewalls in too much and force you to underinflate the tires, or risk getting a poor tire contact patch. I would rather keep the tires inflated properly and have some peace of mind.
You can still drive it, but you do have to be careful with the throttle and not carve those corners the same way you likely do on warm pavement. On the other hand, you should be fine in Oz with your moderate temps year round.
My experience is that the P zeros are poor when cold. It doesn't get overly cold at all here in the Bay Area but below 40 the P Zeros are awful, noticeably lacking in grip compared to warmer temperatures.
Another member, SpinningBull, posted on here that grip with his new PSS was better in the colder mornings that his prior OEM Pirellis.
I have noticed that the tpms goes off anytime it's below 40. But resets once the tires warm up.
Only spin I have had with the pss was during a hard acceleration (3/4 throttle) off a stop light.
Yeah... my inner teenager came out when a dude in a m3 thought he could race me. There was no contest.
That's right. still holds true. While there aren't many cold mornings here I have noticed significantly less slip on the pss. When the car was cold with the pirellis, I would spin just getting out of the subdivision.
#30
+1, you're living with compromised performance in both seasons. Unlike so many others around here, I'm reasonably satisfied with PZeros. Mine are showing zero signs of wear at 6K, and I think the warm weather handling is superb. You do have to seriously dial back your driving style in cold weather, which any sane person should be doing, and they do OK. However, I absolutely stay away from frozen precipitation with them and don't drive the car when that is likely.
#31
I have @ 12,300 miles on the car and it is time to change out the rear tires this spring. I will keep the stock Pirellis on the front, but will change out to the Mich PSS for the rears. I have not tracked the car (more less just some spirited road driving). Should I expect changing out the rear tires between every 12 to 15k miles? How long would you think the front tires should be good for?
I'm not sure if it would be a good idea to fit 2 different tires on your car.
#33
#34
#36
#37
I'm curious, has there ever been any independent study or testing done to verify that this is actually a problem? What actually happens? What is compromised? What are the thresholds before issues occur (speed, driving style, front vs rear etc).
#38
The only thing to watch out for I would have thought is that your limit of traction will be determined by the weakest link but it will be the same general result as if you had the weakest tyre on all four wheels.
No expert here, but just trying to think it through.
#39
Different tread patterns front to rear are irrelevant - you already effectively have that on any car that runs different size tires front and back like the F Type, so the surface area of contact tread is immediately going to be different (smaller) at the front.
Of course, I could be wrong. Working for Australia's leading tyre franchise for 17 years may have taught me nothing.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
#40
That said, I'm too cheap to replace four tires if only two are worn out. You just learn to adapt your driving style to accommodate the differences in tire construction and compound. Pushing the car to 99.99% at the track, I would opt for the same tire all around.
