How to Remove Shifter Surround?
Hi All
I'm struggling to remove the gloss black surrounding the shifter and all the buttons, it was easy enough to get the outer surround off but struggling to find any guide or pics on how to remove the gloss black part.
Any help would be greatly appreciated thank you.
Hi All
Mine's not immaculate either, but that discussion rather ruined my appetite to replace it.
I don't completely remember how i did it but I did.
Remove the trim around the shifter panel
Unclip the kneed pads on each side of the center console and have to undo 2 torx on each side
The rear edge of the black plastic housing is held in by 2 tabs that you have to reach through a slot in the side and pull outwards(found this step to be the most challenging)
You should be able to lift the housing and unplug the connectors and replace whatever you need replace.
I hope this helps a little. Its not the best tutorial but at least it gives an idea.
The following 2 users liked this post by wurldfamuz:
enderle (05-08-2020),
LockNumber25 (04-30-2020)
LockNumber25 (05-03-2020)
The following 3 users liked this post by Tp10XKR:
JacksonvilleJag (05-06-2020)
I did my start button today, I started to go after just pulling the button and was like....damn easy enough to just remove the trim so I used a credit card (wife’s) in case it broke...haha and popped the trim up very easy and with little effort had the new button swapped out and trim clipped back down. simplest job I’ve done on this car!
Received 3,226 Likes
It's the correct button, ridgy didge OEM JLR in Ignis, but a little pricier than say Britcar and the postage is a tad slow.
But last time I checked with Britcar they couldn't source one anywhere.
Rain rain and more rain here, the wettest April in some 20 years and May is not looking any drier.
The "record breaking drought" (it wasn't really, not by a long shot) is well and truly over!
