how to remove trim piece which houses start/stop button
Old 12-02-2020 | 09:16 AM
otokar's Avatar
Default how to remove trim piece which houses start/stop button
i want to add a switch to the lower trim piece which houses the engine stop/start button... any tabs to watch out for?
does it come out easily?
(2015 coupe)
Old 12-02-2020 | 09:25 AM
Jaguar1611's Avatar
If you take a flexible business card/credit card and fold it in a half circle, the whole start stop assy comes out.
Old 12-02-2020 | 09:27 AM
Ray Ray's Avatar
very easy, use a plastic pry tool, insert it under the panel, best to start with the area between the piece and the cupholder, and just pry up.
the piece is very strong so don't worry about breaking it.
Old 12-02-2020 | 10:21 AM
otokar's Avatar
sounds easy! ...thanks!
Old 12-02-2020 | 10:45 AM
Therock88's Avatar
(2015 coupe)
As suggested, lift up from the back with a plastic pry tool or similar and then pull back. An alternative option that I did before switching to the fixed-wing, is to put a toggle in the existing hole under the dash. Your call though.
If you choose to remove the panel to install...This video is a good overview:
DC
Old 12-02-2020 | 11:12 AM
otokar's Avatar
great, thanks, i'll check that first as i have the toggle switch already.
any issues with bumping it accidently?
the video just made it very understandable! thanks
Old 12-02-2020 | 11:28 AM
Therock88's Avatar
Nope. It is pretty well recessed. I am sure there are larger drivers than me....But I am 6'4" and 225 LBS, and I do not bump it. (It is now used for my Methanol/Water Injection to totally disable the system when I do not want it running at all and I still never bump it...But you may??).
You could also use a smaller, or different style switch if you are concerned.
DC
Old 12-02-2020 | 12:21 PM
otokar's Avatar
i just checked and it looks like a good location to me.
Old 12-02-2020 | 02:34 PM
otokar's Avatar
all done. i used the location you suggested.
pretty tight back there to solder the wires but do-able
thanks for the info
OzXFR
08-16-2023 09:47 PM
rickkym
02-17-2020 07:28 PM
XJR033
10-16-2018 06:45 AM
farkle-edina
05-24-2016 11:46 AM
lexoman
05-09-2011 09:21 AM
Quick Reply: how to remove trim piece which houses start/stop button
