How to see the "service required" reason?
Hello all,
I get a quick service required message when I start my car then it goes away. I can't figure out how to read the message or what type of service it is needing. Is there a way to figure this out or do I actually have to take it to the dealer to figure out?
On my MY!8 I use the menu - select Vehicle Information and scroll down to the Service option. I think, I'll check tomorrow.
Steve is correct that it's a timer-based reminder for annual service. That said, it's not uncommon for it to go off when you're not really due - generally because the dealer forgets to reset the counter. If that's the case (or if you just want to skip the message), the procedure to reset the service is:
1) Set ignition on
2) Open hood
3) Open driver's door
4) Fully depress both accelerator and brake pedals for 10 seconds
5) Turn off ignition
If the message still appears, try again.
1) Set ignition on
2) Open hood
Is this a specific sequence?
I think I have tried this last time I changed my oil in my 2015 R; not sure it worked but I have a question.
Is this a SPECIFIC sequence; that is; I have to sit in the car (ideally) to do the first two steps (set ignition and pop the hood ). So, then I would open the driver door and proceed.
Do I have to LIFT the hood or is popping it enough? Because, if I have to exit the car after the hood pop, I would be opening the driver door out of sequence.
So complicated, why can't they just play nice like my 2001 GMC yukon Wait, I know the answer...
1) Set ignition on
2) Open hood
1) Set ignition on
2) Open hood
Worth a try!
I will try it today! Maybe a few times
