How To Upgrade Battery from H7 to H8
This applies to a 2021 P300 and may apply to others.
Translating the battery code on my factory battery showed the battery was built over a year before the car's build date and the voltage tests were showing a battery in decline.
This 4 pot car had the H7 battery whenn new.
Comparing the specs, the height and width for the H8 are identical. The H8 is simply longer.
The H8 has more cold cranking amps, more capacity, more amp hours, more weight, more EVERYTHING.
The battery tray in this car had a small stop bracket spot welded to the aft side of the battery tray.
A cold chisel easily pops this bracket off. Smooth off any burrs and install the H8 BCI Group # is 49.
These cars place tremendous demands on the battery and I'm happier with the additional capacity.
BEST !
RWS
BEST !
RWS
Sparky H (05-01-2023)
Good thing it doesn't rain in the UK.
uncheel (05-01-2023)
