if i want update to a R exhaust from my v6
Old 07-21-2018, 09:37 PM
indietor's Avatar
Default if i want update to a R exhaust from my v6
i need that
https://www.ebay.com/itm/2015-2016-2...VbNWZI&vxp=mtr
only plug and play ? i have the v6 with the active exhaust button and a tune , only remove the original exhaust and put the new one ?
for the bumper i need the valance and the rear bumper ?
thx
Old 07-22-2018, 03:05 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Originally Posted by indietor
i need that
thx
1. Remove the V6 valence pieces below the bumper. (no need to remove bumper).
2. Remove and replace the muffler. This is a simple swap of the box itself. Clamps attach it to the pipes. You will need to lengthen vacuum hoses to reconnect the muffler valves. I used a hose barb and additional piece of hose to do so.
3. You will need items 3, 4 & 7 from the grouping of diagrams at the bottom of this page: http://www.jaguarlandroverrenoparts....ents-rear-scat . Given the expense, you should buy these used from someone who upgraded to a carbon fiber valence.
4. You will also need a pair of V8 fog lamps to fit the V8 valence. The lights from the V6 look like they would fit, but they don't.
Old 07-22-2018, 06:12 PM
indietor's Avatar
can you help me with a pic or something i have some difficult with language but im working on it
if the car is tuned is not important , remove and put new exhaust not put me engine light BUT...im in eu , italy and i buy exhaust from usa , is same or not ?
for emission or engine light , thx
sorry for stupid question but im very inexpert on this
Old 07-22-2018, 06:16 PM
FR500GT's Avatar
That is a steal for a factory R exhaust!
As unhinged mentioned above, there are a few components that are needed. The factory R valance, diffuser and reverse lights and brackets are needed. The exhaust simply bolts right on. However, you will not not need #7 (impact bar) which he probably mixed up with a different part number.
Old 07-22-2018, 06:17 PM
FR500GT's Avatar
No issue with any engine light. This exhaust is a simple bolt on replacement!
Old 07-22-2018, 06:53 PM
indietor's Avatar
so ok
the exhaust is simply remove V6 and put the V8 on and fix it and for the active valve button i need to reconnect the cable ? i never look on the bottom of the car
so after i buy (try ebay) a R valance and the diffuser and reverse light
brackets are the part that uningd mention ? 3-4-7
Old 07-22-2018, 06:54 PM
indietor's Avatar
he can go for 440 usd
and i add 120 usd shipping for italy
Old 07-22-2018, 07:06 PM
Unhingd's Avatar
All illustration numbers I listed referred to the third illustration at the bottom of the page. Part 7 is the tow hook cover. It is not interchangeable with the V6 tow hook cover.
Old 07-22-2018, 07:09 PM
Unhingd's Avatar
+1. No tune adjustment needed. Any changes made to the exhaust system after the catalytic converters has no impact on the emissions system.
Old 07-22-2018, 07:13 PM
Unhingd's Avatar
so ok
The fog lamp brackets are included in the number 3 part grouping. The brackets are separately listed as part 18.
Old 07-23-2018, 02:52 PM
uncheel's Avatar
Hopefully you realize going in that pipes aren't the key ingredient to making the car sound like a R.
Old 07-23-2018, 02:59 PM
indietor's Avatar
yes i know that
i love the look
and if i find to realize in cheap mode i do !
Old 07-23-2018, 05:16 PM
Unhingd's Avatar
+1. However, it has the sweet harmonics of the V6 with more of the decibels, burbles and backfires than the V8. There is a reason that they routed the loud mode through the muffler on the V6 and didn't have to on the V8.
Old 07-23-2018, 08:33 PM
indietor's Avatar
i try to buy for 400 plus 128 shipping cost to italy
so after it's hard to connect the exhaust button to the valves that i immagine is different from the v6
Old 07-23-2018, 09:52 PM
Unhingd's Avatar
I don't know what you are trying to say.
Old 07-24-2018, 12:50 AM
devmen's Avatar
Hi @Unhingd,
Been lurking around here since March when I got my own 2016 V6S--wanting to get an OEM R exhaust on my own. Personally I like the option of making the F type exciting (dynamic+sport) and civilized sometimes. From your experience , would changing to the OEM R exhaust on my v6 take away from having a civilized option (closing the valves)? Some quiet drives are nice (for my passengers).
Old 07-24-2018, 06:57 AM
Unhingd's Avatar
Originally Posted by devmen
Hi @Unhingd,
Flipping the switch to quiet mode will provide a very civilized ride as long as you don't get on it hard or run it over 4000rpm. Under those circumstances the valves automatically open even if quiet mode is selected. As verification, my spousal unit has not yet commented on an overly loud exhaust (such a pain to keep it under 4k). With theV6 exhaust she would not tolerate the loud mode. I now mostly keep it in quiet mode and use the throttle to modulate the exhaust valves.
Old 07-24-2018, 11:49 AM
indietor's Avatar
ok
i try
i remove the v6 diffuser and remove the exhaust. i only need to remove it or need to remove some cables ? ( i immagine cables for control the exhaust button in the console) if yes
after when i mount the v8 ehaust i fix it and after i reconnect the cables ( hope i understand the procedure) to the new exhaust
right ?
Old 07-24-2018, 12:13 PM
ok
i try
right ?
If it's for visual reasons, go for it. If for sound reasons, it won't sound much different to the exhaust you currently have.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old 07-24-2018, 12:21 PM
devmen's Avatar
Definitely considering this for looks, but from my research the R exhaust makes the V6 sound meaner .
@Stuart@VelocityAP , definitely considering a tune down the road to actually make mine meaner 😇
Quick Reply: if i want update to a R exhaust from my v6
