if i want update to a R exhaust from my v6
i need that
https://www.ebay.com/itm/2015-2016-2...VbNWZI&vxp=mtr
only plug and play ? i have the v6 with the active exhaust button and a tune , only remove the original exhaust and put the new one ?
for the bumper i need the valance and the rear bumper ?
thx
thx
i need that
thx
thx
2. Remove and replace the muffler. This is a simple swap of the box itself. Clamps attach it to the pipes. You will need to lengthen vacuum hoses to reconnect the muffler valves. I used a hose barb and additional piece of hose to do so.
3. You will need items 3, 4 & 7 from the grouping of diagrams at the bottom of this page: http://www.jaguarlandroverrenoparts....ents-rear-scat . Given the expense, you should buy these used from someone who upgraded to a carbon fiber valence.
4. You will also need a pair of V8 fog lamps to fit the V8 valence. The lights from the V6 look like they would fit, but they don't.
if the car is tuned is not important , remove and put new exhaust not put me engine light BUT...im in eu , italy and i buy exhaust from usa , is same or not ?
for emission or engine light , thx
sorry for stupid question but im very inexpert on this
That is a steal for a factory R exhaust!
As unhinged mentioned above, there are a few components that are needed. The factory R valance, diffuser and reverse lights and brackets are needed. The exhaust simply bolts right on. However, you will not not need #7 (impact bar) which he probably mixed up with a different part number.
so ok
the exhaust is simply remove V6 and put the V8 on and fix it and for the active valve button i need to reconnect the cable ? i never look on the bottom of the car
so after i buy (try ebay) a R valance and the diffuser and reverse light
brackets are the part that uningd mention ? 3-4-7
so ok
+1. However, it has the sweet harmonics of the V6 with more of the decibels, burbles and backfires than the V8. There is a reason that they routed the loud mode through the muffler on the V6 and didn't have to on the V8.
Hi @Unhingd,
Been lurking around here since March when I got my own 2016 V6S--wanting to get an OEM R exhaust on my own. Personally I like the option of making the F type exciting (dynamic+sport) and civilized sometimes. From your experience , would changing to the OEM R exhaust on my v6 take away from having a civilized option (closing the valves)? Some quiet drives are nice (for my passengers).
Hi @Unhingd,
ok
i try
i remove the v6 diffuser and remove the exhaust. i only need to remove it or need to remove some cables ? ( i immagine cables for control the exhaust button in the console) if yes
after when i mount the v8 ehaust i fix it and after i reconnect the cables ( hope i understand the procedure) to the new exhaust
right ?
i try
right ?
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
ok
i try
right ?
i try
right ?
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
