If you're approaching 60k miles, *change* your Spark Plugs and Fuel Injectors
Old 08-05-2021, 12:38 PM
Therock88's Avatar
Another tool(s) that may be needed, or at least helpful (IF) you are replacing with new injectors/seals are the seal install tools. These allow you to get the seals positioned correctly to install. Again, there may be other options, but this would be preferred...
DC
Good explanation here -
Old 08-05-2021, 01:24 PM
Andi Jaguar G's Avatar
I have 8 new for my switch. So I think I need not other tools for change rings or something?
Old 08-05-2021, 01:26 PM
[QUOTE=Therock88;2424673]No matter what mileage you have, you need to use the injector puller tool. No reason to risk creating issues you do not need to. Tool is a simple slide hammer fitted for these injectors.
DC
[/QUOTE
Where can I buy this slide hammer?
ThNk you so much
Andi ]
Old 08-05-2021, 01:35 PM
XxMerlinxX's Avatar
ThNk you so much
Andi ]
I picked mine up off of Amazon. Let me know if you can't find one and I can just mail you mine, hopefully I won't need it again anytime soon! (feel like I just jinxed myself)
Also, you don't need the seal kit if you're buying brand new injectors, the injectors come with everything that you need except for the metal retaining clips. Those can be reused from your old injectors with a little bit of work.
Old 08-05-2021, 02:24 PM
Amazon Germany nothing, what is looking as your's... Is this tool good for pulling out the old one, or an installation help for the new one?
Old 08-05-2021, 02:27 PM
Ah, this one!
Old 08-05-2021, 02:32 PM
Ah, this one!
  #28
Old 08-05-2021, 03:05 PM
I buy this one, Jaguar V8
Old 08-05-2021, 09:14 PM
lizzardo's Avatar
Originally Posted by Obi
s1 redline (and wmi) will clean intake.
Lucas fuel injector treatment will help clean the fuel injectors. These injectors don't necessarily break, they just get stuck open
Do you mean Redline SI-1? I can see WMI helping clean the intake valves but no fuel additive will ever see anything other than the combustion chamber face.
  #30
Old 08-05-2021, 10:31 PM
Obi's Avatar
Obi
Obi is offline
Yes, mistyped/ categorized.
Redline and lucas can clean the injectors.
WMI, media blasting, carb cleaner etc to clean the intake valves
  #31
Old 08-06-2021, 10:05 AM
Sparky H's Avatar
New to social media....what is WMI? just a cowboy tryin to get educated on this computer.
Thanks in advance.
  #32
Old 08-06-2021, 11:15 AM
Obi's Avatar
Obi
Obi is offline
Thanks in advance.
Water methanol injection system. Best cooling modification for the car but it requires some permanent changes (drilling holes in the upper intake manifold). Typically wouldn’t be done until youve modded the car (tune, pulley(s), cats)
  #33
Old 08-06-2021, 11:23 AM
Mahjik's Avatar
Thanks in advance.
Water/Methanol Injection
  #34
Old 08-06-2021, 12:33 PM
Sparky H's Avatar
thank you Sir(s)....I understand.
  #35
Old 08-06-2021, 01:57 PM
XxMerlinxX's Avatar
@Andi Jaguar G yes, that's the tool that you will need. It helps tremendously with pulling the injectors out. You will also need a Torx T30 bit and a short ratchet in order to reach the bolts on the coil pack. The thread located below has a good list of items needed and pictures to help with removal of the parts.
https://www.jaguarforums.com/forum/f...p-step-220006/
George05 (08-06-2021)
RagTopJag
05-27-2021 07:41 PM
new mexico
07-06-2017 04:28 PM
dawesboat
XJ40 ( XJ81 )
03-12-2012 03:59 PM
Jon89
12-09-2009 02:25 PM
Quick Reply: If you're approaching 60k miles, *change* your Spark Plugs and Fuel Injectors
