Improving the stock intake: More flow, lower IAT's & More SC noise!
#61
I removed the stock air boxes on my XJ and fitted giant cone filters with the Mina intake tube. INSANE supercharger whine. It actually startled me on the test drive. No joke, it's almost as loud as a Hellcat or Demon when in Dynamic mode. Open cone filters are the key to unlocking the noise. Leave the factory snorkels and create some sort of heatshield and you're golden.
thanks!
#62
Had a response from ITG, it is as below:
"Hi Andrew,
Many thanks for your interest in ITG air filters.
We do have an option for the F type which utilises 2 x Silicone elbows and 2 x large Maxogen air filters.
This would be fitted onto your OE MAF housings. It replaces the stock intake, which includes removal of the lower half of the stock airboxes.
We can look to supply you this at £245 + VAT,
Look forward to hearing from you,
Best regards,
Sahd Sharif
Development Engineer"
I am guessing this is just deletion of the air boxes and a pair of cone filters which attach to the maf housings, not what I am ideally looking for, however the price is extremely good at just £245 +VAT ($340). I am sure they ship to USA as well.
His contact details are:
Sahd Sharif
Induction Technology Group Ltd
Siskin Drive
Coventry
CV3 4FJ
Tel: 024 7630 5386
Fax: 024 7630 7999
Email: technical@itgairfilters.com
"Hi Andrew,
Best regards,
Sahd Sharif
Sahd Sharif
Siskin Drive
Coventry
CV3 4FJ
Tel: 024 7630 5386
Fax: 024 7630 7999
Panthro (06-26-2018)
#63
#64
The setup hasn't caused any codes and the fuel trims are perfect. No discernible difference in performance but the WHINE...oh boy, the whine is incredible.
Unfortunately, I think the older Denso models don't have MAF tubes separate from the air box so I'm not sure how you would set this up, but everything can easily be reverted back to stock on the Bosch units.
I didn't bother posting this before because historically the Jaguar Forum members have not been receptive to intake mods. The age-old arguments about paper vs cone filters, CAI vs stock, blah blah blah, always seem to come up. In no way am I saying this is any kind of "performance" mod. It is done purely for increased supercharger whine. And when I say "increased", I mean LOUD.
I'll try to get some pics this weekend.
Panthro (04-30-2018)
#65
Nice feedback and what you have done sounds like what ITG is offering for $340 which is essentially a pair of cone filter and some silicon bent tubing to connect the filters the maf tubes on the bosch models which SVR's are.
Guess its something I could give ago as £300 is not hugely expensive just not sure about running cone filters.
I do wish we could monitor IAT on our cars then at least could see what modifications work and don't for IAT, normally open cone filters suck in much warmer air from engine bay, though I suppose in the F-Type the filters are low down in front bumper behind the partially blocked vents.
#66
#67
Well I made an experimental ram air setup for my F-Type at weekend, thought its not truly a sealed ram air as I simply inserted some short lengths of brake duct cooling hose into the snorkels to extend said snorkels to directly behind front grill.
Using cable ties tied them down to hold in position behind front grill, in short the catch the air entering the grill more efficiently and thus the faster you go the air box gets more air than its requesting and thus trying to create ram air situation and of course help reduce IAT's.
Thought its not a perfect science I got one run at drag strip today, unfortunately it was insanely busy so I'd had the engine idling 90 minutes before my first run, in similar situations with excessive engine idling in staging and thus everything heat soaked I was running around 1.44's and a previous PB of 1.3080 from when the engine was not heat soaked and on 2PC brakes.
Well today even with not ideal conditions I ran a new PB of 11.28@124mph and feel that could certainly be improved upon some more, but in short, does it help, unknown, has it had an negative impact, certainly not.
So now probably time to perfect it by getting some proper air scoops made by Velossa or by making my own from a combination of brake ducting and brake air scoops and position them carefully behind front grill to not block radiator flow, at present the rough mockup has no impact of radiator flow.
#69
That would be amazing if there was, would put a bit of true science to this testing. As good as drag times are, they can be effected by other aspects such ambient environmental conditions, tail winds or head winds, heat soak issues etc.
So really today I was testing to see if experimental ram air setup would have any negative impacts. So to run a PB I think is fair to say its having no negative effect, was it the reason for the PB, thats a total unknown, but I did not perfect my tyre pressures today like I normally do so even more impressed to run a PB but this car continues to impress me to run an 11.2 stock.
#70
#71
Received 3,237 Likes
I use Torque Lite (free app) on my android phone (Samsung) with an Elm327 OBD2 plug and one of the things it shows is IAT in real time.
I'm fairly sure you can also get Torque Lite for iphone.
Guest1 (04-29-2018)
#73
#74
OK those snorkels are definitely different to my SVR, they sit much higher up making it even harder for them to get cooler air (worse) so if anything SVR snorkels would be an upgrade as they are shorter.
Also I'd suggest due to how high those are, it would not be possible for velossa to make anything to work on those and probably not possible to do what I did on mine.
Though I do see possibility, if you cut away the front piece of those snorkels that appear after the crash bar, effectively opening front top half, then put a lid on them they would effectively act as massive air collectors naturally catching the air, of course do make sure the hole in the bottom of your air boxes is present, to ensure they don't also catch water and fill up.
P.S. Assume you started car without air boxes on and gave a few revs to listen for SC noise? Should of made a recording with air box and without. Kind of makes the ITG cone filter option interested considering its only about $350. My only worry with cone filters is the air boxes get quite dirty, but with just cone filters would result in cone filter covered in dirt.
#76
I suspect too much dirt would enter and over time heavily reduce the filters ability to flow air and risk of dirt particulars as I did notice the air boxes were very dirty on outside as the SVR bumper lower side vents are open so a lot of road dirt gets in there.
#77
Yep, but I'd say those stock ones are better for modding, I'd literally cut the front piece of above bumper bar, just leaving the sides and back intact, then out of the cut off piece, cut to size a piece to put a lid on them and then another piece angled from lid to back to help guide the air down into them, just use some good heat proof glue.
You then have to massive air collectors. I might buy a pair, modify them and fit in place of my SVR ones.
Also the SVR ones seem designed to catch more air but also at the same time to allow more air to radiators as those do seem to somewhat block the radiators very marginally.
#78
Here is a picture of the SVR snorkels again, I made image brighter so you can see in more detail:
![](https://i1145.photobucket.com/albums/o504/Gibbo205/SVR/5_1.jpg)
Here is my very rough modification for now, to direct more external air into them and catch colder air at speed:
![](https://i1145.photobucket.com/albums/o504/Gibbo205/SVR/thumbnail_IMG_3653.jpg)
![](https://i1145.photobucket.com/albums/o504/Gibbo205/SVR/thumbnail_IMG_3654.jpg)
![](https://i1145.photobucket.com/albums/o504/Gibbo205/SVR/thumbnail_IMG_3652.jpg)
To perfect this I would use slightly larger diameter ducting as what I had too hand was a little too small and the snorkels can certainly accomodate slightly larger for a more snug fit and of course larger opening to car more air.
Then to ensure they catch more air and to make them neater you could finish them off with a brake duct, something like these examples:
![](https://www.merlinmotorsport.co.uk/files/resized/large/I/img/id152_51.jpg)
![](http://www.burtonpower.com/media/catalog/product/cache/1/small_image/280x/9df78eab33525d08d6e5fb8d27136e95/R/e/Revotec_Ducting_Joiner.jpg)
![](https://i.ebayimg.com/thumbs/images/g/HRwAAOSwQNRZvOq6/s-l225.jpg)
Just some examples to neaten it up and catch even more air, of course as its behind the grill and in a dark area you don't see what is back there.
I shall probably just buy larger ducting to fit in the snorkels snugly, then use these on the ends behind grill for neatness but also because the lip will provide good securing point for zip ties:
http://www.revotec.com/acatalog/Black.html
#80
