InControl App remote starting?
#41
#42
If you haven't ruined the fod by accidentally soaking it in salt water, or if it hasn't been eaten by seal. The same goes for the iPhone. That's why I think the activity key is a neat idea. You can't stash your F-type fod in a wheel well like a normal key so the activity key is necessary.
#43
Unfortunately for surfers, the Apple Watch is not water proof and it needs the iPhone for the functionality (right?). If the Jaguar InControl remote could disable the fob when the latter (and the iPhone) is stored in the car, and the Apple Watch was waterproof (it can survive a 1 mile swim in a pool), it could be an alternative to the Jaguar activity key.
#44
#45
The viper uses a phone to replace the key. That's not much of an improvement if you want to go into the water. Loosing your phone in the ocean is much worse than your car fob. I guess putting the Viper system in won't enable your car doors to touch open so you can hide the phone under the car (not something I want to do). There is a Korean product that looks like the jaguar activity key (smart pass keyfree RF). It uses a RFID bracelet like the Jaguar activity key, but it would not inactivate the car's key fob, so the problem of hiding the fob far enough away from the car to disable the touch open on the car remains. Taking your F-type to the beach to go swimming forces you to act like a pirate hiding his treasure in the sand (maybe that's what those guys with metal detectors at the beach are looking for Jaguar key fobs to they can steal the car).
I called my local dealership and they said the activity key is only factory installed. So unless the Viper eliminates the need for the current key fob, allows you to get in and drive the car without fussing with the app, and knows to tell the difference between the iPhone and iwatch, this also does not solve the pirate treasure problem. I guess this kitty doesn't like going to the sand box.
#46
BigCat09 (01-06-2017)
#47
A good way to prematurely wear out my fob. I'll use another car or stick to my local beach instead.
#48
I found a possible solution for surfers and ocean swimmers. The FobGuard?: Ideal Faraday Cage to Protect Car Keyless Entry Fobs to store the fob in the car and Vision America (Vision Tech America, Inc. ? Backup Camera and Monitor // Back Up Camera ) sells the Keyfree touch system (KEYFREE TOUCH ) in he US. You can also get Keyfree tough gen 1 from Amazon for $78. I'll get the fob guard ($30 Faraday bag for a key fob) and test it out. Note, in the thread key stolen from fob, I posted a like to wired magazine on how car thieves use a signal boost to extend the range of the fod so they can steal your stuff in the car...a keyless car may not be ideal for going to the beach unless you want to hide your treasure 200 yards from your car...I don't want to get sand under my finger nails...plus there's the metal detector guys to worry about.
#49
![Icon Worthy](https://www.jaguarforums.com/forum/images/smilies/icon_worthy.gif)
#50
#51
#52
#53
FYI: If you're on Android, do not update your OS to the new 7.0 (Nougat) unless you don't mind losing the InControl app. Jag has not yet updated it, as it's apparently crashing for most if not all users. I just received the update and the app does not like it. I contacted Jag and they're aware of it. They asked for my phone's make/model and they're supposedly addressing this issue.
Mbourne (09-01-2016)
#54
Burt Gummer (01-06-2017)
#56
My app on my iPhone and watch have not worked since 12/23/16. IT is very unreliable and always says it is in sleep mode no matter how I try to trick it or wake it up.
How can we maybe get a group buy or find the activity band cheaper as I am interested in it? Can we start a thread o the band or post our findings on a buy for these here?
#57
I found this so far, the small print still makes it expensive Think. I assume the install kit is the antenna that needs to be placed inside the car for the band to read the code?: https://jaguarsacramento.niello.com/...&page_number=7
F-Pace Activity Key - Wristband - T4A11596 - Genuine Jaguar at www.rimmerbros.co.uk
Activity Key - Polsband
#59
Have been using In Control app to remote start my F-Type for several years, with moderate success. Failure to connect has been the main problem. However, recently (like within the past week?) I get a message about "sleep mode" and it says I have to drive the car to wake it up. I just drove if <8 hours prior. I've set the "wake up date" on the app now, but have never seen this before. Anyone else seen this problem? I had the wake up mode switched off, it turns out (had never looked at that setting before, as I didn't seem to need it); if I turn it back off, will that eliminate the "sleeping sickness"?
#60
