Infotainment related issues
First off, I've got a 2016 F-Type S Coupe (w/upgraded Meridian system). I'm having the following issues (not sure if related):
- Music/radio stops, cell phone bluetooth disconnects and navigation stops working all at the same time. This usually happens near the start of the drive and occasionally throughout the drive.
- HD radio signal cuts out constantly (every few seconds at it's worst). I usually just disable HD radio as it's extremely annoying. Don't have this problem in my other car with HD radio so I don't think it's a weak signal issue.
- Radio fade/volume randomly changes. This is different from the volume changing when going between HD and non-HD signals. It's almost as if most of the sound is pushed to the front speakers and lowered. Definitely happens on non-HD signal... I haven't really noticed on HD since I can't use HD much. UPDATE: Also noticing it fade from side-to-side instead of just front-to-back.
Hey,
have the same problems in my MY2015 F-Type with the upgraded Meridian as well. Regarding Problem 3 the fading is not the problem for me, but sometimes some speakers just stop working. Exchanged the amplifier with no improvement. Seems to be that another module don't like the change without attention ;(
Currently also with no clue how to solve the issue.
Kind regards from Germany
Likewise amplifer problem not going to affect these either
I think dealer visit your best bet as going to be hardware issue and hard to diagnose
You could try unplugging and reseating all the connectors in the back of the infotainment headunit in the meantime
