Intercoolers
The aluminium part on top of the engine is an air/water (it appears to be plumbed in to the engine cooling system) Intercooler.
Making it colder, and/or bigger boosts power through increasing the density of the air going into the engine and/or getting more pressurised air into the engine.
If you live in the Northern States of the U.S., or Canada, there's another reason why it's so much easier to spin the wheels in the Autumn...
pv=nrt. So a 5% drop in absolute temperature will mean 5% more oxygen going into the engine available to combust.
So the question is more whether this circuit works more like the heater, or the aircon radiator in the climate control. The former will be at close to boiling point, while the latter will be close to freezing point...
This is worth further research for sure. I wonder if a larger heat exchanger would be a cheap source of a few hp.
I have heard that the supercharger heats up pretty quickly under sustained boost, and that it really only starts to build boost at all over 2,500 rpm. So I guess it makes some sense to keep it under 2,500 rpm especially at lower road speeds or hot weather if you want to have a cool charge available when things speed up. I pretty much do that anyway to keep the oil temps reasonable.
Gauges, we need gauges...
Keep in mind, there are 2 heat exchangers in that circuit:1) Ambient air to water heatx that sits in front of the conventional radiator and compressed air to water intercooler at the outlet side of the SC. I would think both would need to be enlarged for significant additional cooling. Of course, without knowing the effective surface area and fin design of each of the 2 heatx's it would be difficult to ascertain which heatx would be best to modify. Alternatively, as Nookieman states so eloquently: Gauges, we need gages. Inlet and outlet water temps of the front heatx and inlet and outlet air temps at the intercooler, would empirically indicate where the cooling bottleneck lies. The intercooler on my MINI is an air to air heatx. With this system, simply adding 50% more fin surface with the special edition GP intercooler made a very noticeable difference in performance, particularly on warmer days.
A Google image search shows sectioned jaguar intercoolers.
I've been curious to collect data on this as well. Therefore I setup a DAQ setup to start logging all engine parameters I was interested in . I have a couple CHT's and EGT's that run to a Thermocouple Amplifier. I'm going to have everything plumbed in once I finish the headers.
I'll post the 4.2L data I collect on the intercooler/ heat exchanger to aide in back-calculating for surface area. I plan to build a next heatexchanger for my test car and see if/any gains can be achieved within size limitations.
I'm hoping to start on the 5.0L data collection in a few months.
Regards,
Derek Fricke
Regards,
Derek Fricke
So glad you have the passion for Jaguars. I can't wait to see your headers installed and see how much of an improvement they are.
Hey I bet you'd like this. While researching available roots superchargers for my motorcycle (the mini Aisin Roots were pretty neat) I came across a supercharger I had only seen photo's of once. I had read that they were for only a narrow powerband, but that seems to be the hand made ones from the 50's. The modern ones are quite different due to the manufacturing improvements.
It's the Latham Axis supercharger. I found a Mazda forum where the modern day owner of the company (purchased from the FL inventor, Mr. Latham) was posting updates for his new kit for the Mazda RX8. When he started the company back up but with modern CAD CAM machines he was able to get much better tolerances than was possible when the original inventor built them by hand in the 50s.
Axial Flow Supercharger - RX8Club.com
(have to copy and paste one to get to the site)
The second owner was producing them in much larger numbers in the early 80's, with up to 1,000 sold. Not just for cars but also unlimited powerboats and WWII Mustang replica's with 600 ci engines.
He stopped back in the late 90's and is now offering them again, but out of solid billet. Really cool read. They do not superheat the air and require no intercoolers. They're very small as well. About the size of a alternator for the RX-8 engine.
I think they're going to price out around $4k + depending on the size. Just a cool tidbit for anyone that likes stuff like that. Anyway, keep up the good work for the Jaguar team.
Cheers,
Cheers,
One of the common modifications to the intercooler system on these cars is to fit a larger more efficient electric pump to the intercooler circuit.
On the earlier cars it was fairly common for the pumps to fail, which caused a loss of power as the ECU has to respond to the higher charge temperatures.
I won't say there is a hp gain to be had from the larger pump, think of it more as a "recovery" over the crappy stock pump, and a preventative action because the stock pump will fail sooner or later.
The stock pump on the F-Type is the same as the XF, XK, earlier cars, etc...
The commonly used pump is an AMG/Mercedes OEM part made by Bosch, part number ending in 010. Here's a good thread from the XFR guys https://www.jaguarforums.com/forum/x...pgrade-152574/
MagnumPI (11-10-2015)
rocklandjag
10-18-2017 07:18 PM
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
02-11-2016 06:03 PM
