View Poll Results: What is your level of interest in a helical gear differential?
Voters: 15. You may not vote on this poll
Interest in helical gear differential development
The Ask: What is your level of interest in commissioning a helical gear differential for modern Jaguars?
The Back Story: I am trying to develop a limited slip differential solution for the following Jaguars with DANA 44 AdvanTEK rear axles.
Thanks, Herman
- F-Type, F-Pace, XF
- possibly some XE and XJ models
- Maintenance free as there are no clutches or springs
- Quiet operation with no clicking or ratcheting mechanisms
- Both forward and reverse torque transfer capability
- Instant torque transfer
Thanks, Herman
Please consider "voting" in the above poll.
And spread the word to any other forum members.
@tbird6 @Richard Chrimes @alphakinase @Dan Wink @lizzardo @JgaXkr @Cambo @airthirtytwo @SinF @jlsthlm @BONESTOCK @Unhingd
https://shop.drexler-motorsport.com/...al-jaguar?c=84
You should ask Drexler, because according to this, they already have one to suit the GKN diff.
The following 2 users liked this post by Cambo:
HermanWiegman (01-11-2023),
Panthro (03-23-2023)
@Cambo Thanks for sharing the link to Drexler Motorsports. They hadn't hit my radar yet.
Their homepage shows a cut away of a diff with friction disks, and their part description for the Jag uses "discs".
I was hoping to commission a helical gear diff (Torsen, TrueTrac, etc) which are maintenance free, otherwise we need to install a disk rebuild kit every XX kmiles.
Drexler provide mechanical drawings! OMG! I love German engineering firms.
Let me dig a bit deeper, and see what Drexler can do for us.
These drawings may also tell me if the XK/8 series have similar diffs to the DANA 44 AdvanTEK cars (F-Type, F-Pace, XF, etc.).
I voted as "somewhat interested" because I haven't had any real issues so far other than a pinion seal (replaced under warranty). An LSD was a "must have" for the car and that's what I've got. A Torsen unit would be a step up, but cost will be the deciding factor, including all parts and labor.
@Cambo Thanks again for the link. Here is what I discovered.
Drexler Motorsports lists two Jaguar compatible parts:
Part number SD-100-100-00089 for XK8 (X100) and early XK (X150)
Part number SD-100-100-00382 for XK (X150) (later models?)
The first unit (-00089) shows an axle shaft with 25 splines and a 34.6 mm OD.
While the 2nd unit (-00382) hosts an axle shaft with 31 splines and 35 mm OD.
The second unit is a match for the F-Type V6S and V6 MT cars with 3.31 reduction ratio.
But it can not directly support some of the other Jaguars with DANA 44 AdvanTEK rear axles with different gear ratios, but it is very close.
The only significant change would be the Crown Wheel location relative to the left bearing seat. An easy modification of the Drexler part.
Note: these Drexler LSD's are based on a friction disk engagement mechanism, so a potential replacement of the stock Jaguar LSD.
Does any forum member have experience with this unit? (perhaps XK? or XKR?)
Update:
After reaching out to several potential suppliers, I have engaged MFactory to build a Helical Geared Differential Kit for our Jaguars.
This custom differential kit is designed to serve a wide range of Jaguar applications.
To date, the below fitments have been configured.
- Jaguar F-Type Automatic Base Model (340 hp) with 3.15 rear axle tagged EX53-4A213-DA (JLR part number T2R 17980)
- Jaguar F-Type Automatic S Model (380 hp) with 3.31 rare axle tagged EX53-4A213-AA (JLR part number T2R 4000)
- Jaguar F-Type Manual Base Model (340 hp) with 3.31 rear axle tagged EX53-4A213-FA (JLR part number T2R 18657)
- Jaguar F-Type Manual S Model (380 hp) with 3.31 rear axle tagged EX53-4A213-BA (JLR part number T2R 1783)
- Any other Jaguar application where the owner can take measurements of the differential carrier flange height.
- start with 3.0L gasoline, expand to 2.0L & 5.0L gas and diesel with the DANA 44 AdvanTek rear axle carrier
- applies to F-Type, F-Pace, XF, and XJ (X531) and perhaps some others.
- The helical geared carrier, maintenance free, torque bias ratio of about 3.0,
- A Ring Gear Shim which locates the Ring Gear laterally in the case to +/- 0.1 mm of OEM position
- new Ring Gear Bolts that are class 12.9 and of the right depth to engage 15 mm of threads
- Directions on upgrading your OEM rear axle housing with the helical geared differential
- Custom Bearing Shim Kit to allow for precise alignment (shims are not available from JLR)
- New carrier bearings to press onto the carrier (high quality bearings, also not available from JLR)
- optional: gear marker grease, paint brush, dial indicators, calipers, and other tools with core/deposit charges
I would buy one.
I voted (very interested). As our platform ages and increased HP options from companies such as Velocityap arrive failure rates will also continue to increase. It is my opinion that due to the current trajectory of auto manufactures (EV) upgraded and replacement parts will have a demand as there are many enthusiasts such as myself that cringe at driving a soulless, unattractive, silent vehicle, that does not allow an owner to maintain without an electrical engineering degree.
As a great movie once stated “If you build it, they will come” including myself. Best of luck.
I will drive this until I can't drive anymore.
The following 3 users liked this post by pab74:
The following 2 users liked this post by spinningcog:
HermanWiegman (02-18-2023),
55
08-11-2014 12:25 PM
