Interior Hatch Panel Removal - Strobe Controller Install
Has anyone endeavored to remove the interior trim panel on the rear hatch of the coupe? I want to wire in a strobe controller for the top brake light.
https://www.superbrightleds.com/more...UA#tab/Reviews
Thanks, Skizot!
I appreciate the file. After reviewing the .pdf, it doesn't look like removing the outer LED panel will allow me the access I was looking for to run a cable through the interior rubber conduit from the headliner area into the rear hatch. I was hoping that the interior hatch was comprised of parts/panels that could be disassembled enough to allow me access to fish the cable from the rubber conduit boot in the hatch and then route through a small hole made at the opposing edge of the interior hatch where it meets the glass.
After looking at the situation a bit more, I suspect that the interior hatch is made of a solid piece of composite material that would make my plan more difficult than initally anticipated.....am I right or am I failing to see things correctly?
Thanks, Skizot!
I helped develop this one: https://coupeconcepts.com/
We made it as small as possible so it would fit into a MINI. Quality unit. Been running mine for 17 years.
I am no longer in that business but Greg is a good person. We could probably get a group buy together with him.
Thanks again, skizot -- your additional files will help, too. I'm sorry if my question was confusing because it was attached to the "3rd brakelight" thread. I had googled "rear hatch disassembly f type" (or something like that), and this thread came up so I jumped in --- maybe I should've started a new thread. In either case, thanks again
skizot (03-23-2023)
Update: the files that Skizot sent provided me the information I needed to almost get the job done. The only hiccup I had was when I removed the (6) nuts for the third brake light cover on the outer hatch and still couldn't get the cover off. With the nuts removed, I was able to easily slide the cover from front to back freely, but I still couldn't lift the cover to remove it. It seemed as if there was another clip holding it in the center of the panel (around the antenna area). I tried many different times, but didn't want to get too forceful and break anything. Can anyone offer any advice to help me remove this 3rd brakelight cover? 2018 FTR.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
I won't be able to try this until later in the week, but I am happy to try and do the same modification you are trying to do. I believe that these components can be tricky at times, but if I had to take an educated guess, you might have one of the cables caught on the underside off the stop lamp, especially considering the XM antenna pod is right there. I would take a plastic trim tool and perhaps a micro fiber to go around the edge of the stop lamp and gently pry upward to get it to release. It should just pop up and come off.
I'll try your suggestion sometime this week ..... your belief regarding the XM antenna sounds like that may just be the problem I am having with the panel removal. I'll give it a try in the days ahead and will report back
