Interior Tweaks
I ordered these puddle lights. Looked at these month's ago and I could have sworn they were round and required drilling and were a PITA.
These supposedly pop right in. I like the clean look of this particular projection.
2x Ghost LED Door Step Courtesy Shadow Laser Lights For Jaguar F-TYPE 2013-2015 | eBay
Received 3,216 Likes
Coz before I fitted the logo puddle lights I fitted a pair of bog ordinary T10 SMD LED bulbs in there with no problems (although they did flicker a bit!).
Pop the OEM ones out (gentle lever with a small flat head screwdriver), remove the connecting plugs, plug the new ones in, click into place, and Bob's your uncle!
The round ones that require drilling are for cars that don't already have puddle lights in the bottoms of the doors (like the XF which has them on the undersides of the exterior mirrors).
Buckingham (03-28-2017)
CRS
In the dark such as at night time they are quite dramatic, but in sunlight or bright light you can't see them at all.
They are also fairly clean and crisp, I was pleasantly surprised how much as I was expecting them to be a bit vague or fuzzy.
As I explained above I can't show you a pic of mine, I tried but the camera flash just completely washes out the logo.
#30
#31
#32
OK. I ordered an ignis orange start switch. Used to be more than $100, now $25. According to Edmunds, the ignis orange was discontinued because it wore off the paddles leaving the white plastic exposed. So they dropped the entire line of paddles, dynamic control switch and start button. I always liked it and it was pointed out by Jay Leno when he did a Garage segment on a the F Type on his show.
#33
Is your car broken? the steering wheel is on the wrong side :-). Seriously the lights and mods look excellent. nice job!
#34
#35
#36
#37
The ignis discoloration issue mentioned doesn't occur for everyone - anecdotally it seems to depend on the amount of acids and other things you have on your skin, what you use to clean your interior trims (you should only use water), and whether the car is exposed to very hot ambient temperatures. Basically the soft-touch clear layer over the painted base breaks down and goes slightly tacky. On areas that have full finger contact like the paddles and start switch that usually leads to gaps appearing where you normally press them, which much like the clear coat on body panels causes the visible colour to change, but it can affect any of the interior switches with that same soft-touch paint finish.
Up till around 2015 that finish was used extensively across many car makes and models to create a more premium plastic finish, until it was addressed. It wasn't just car parts either, I have used TV remote controls and computer mice with the same issue. I don't think the ignis painted parts are still made so replacements likely will experience the same issues if any of the degradation causes are still present.
#38
RickyJay52 (03-31-2017)
#39
#40
Because of this thread, I bought both the logo ghost lights for the doors, and the copper start button.
The start button installed in five minutes. I used a trim tool to pop the shifter trim ring up, disconnected the harnesses, and swapped out the buttons. I paid $30 shipped for the button on eBay.
The ghost lights were $20 from China, so I should be seeing those in the next 8 weeks haha.
