Introducing Me
Sounds like a rather interesting car...
@AJB2 Maybe Jaguars' OSH may be able to shed more light on where it's been and from. https://osh.jaguar.com/
Hoping not to see the word Copart in there! ;-)
Copart (Special Vehicle Operations)Acrey Fields, Woburn RoadBedfordshireBedfordshireMK43 9EJUnited Kingdom01234 762213B561630/11/20166699 miles
Service Completed16000 miles / 12 months serviceOther Related ItemsRenewal of Oil and Oil FilterRenewal of Brake FluidRenewal of Pollen FilterRenewal of Engine Air FilterRenewal of Alarm Handset BatteriesAir Conditioning Service
This is how it is written
Inchcape Land Rover, Guildford1 LadymeadGuildfordSurreyGU1 1DTUnited Kingdom54999
![](https://osh.jaguar.com/resources/images/jaguar_brand_logo.png)
Service Completed48000 miles / 36 months serviceOther Related Items
AJB2 (04-15-2019)
Based on production sequence number, the car was definitely built during the MY2015 production cycle (March 2014- February2015). The features indicate an MY2016. If the VIN truly belongs to this vehicle, you have a rare pre-production unit that was used for real world testing or produced as a press vehicle. Given the production date, most likely the former. Other than this car, I know of no regular production MTs with a sequence number of anything less than a 27xxx.
#30
No way Jaguar road-tested for 2 years and not seen slipping clutch issue. I am skeptical that OP somehow got an early MT prototype (that probably never existed) and it was updated with a later dash and so on.
It is typo in a document or hoax or VIN rebadging to hide bad title history.
#31
Unhinged...I cannot for the life of me get the car to repeat the “Clutch Slip” I’m now wondering if, due to the danger of the situation I was in when it happened, If it was the rear wheels spinning causing the lack of grip & smell? To be honest, I just needed to get out of the situation fast & didn’t take a lot of notice what was happening...the smell was like hot brakes...
#34
#35
#36
Do a full throttle zero-60 run with a fast 1st to 2nd shift. If you have the dreaded 1st generation clutch, the clutch will not fully engage in 2nd gear and will just initiate a meltdown until you let off on the throttle. Then it will catch and act like a clutch in good condition. Gentle drivers will never experience this slippage.
Your description of the situation certainly indicates you have this issue.
AJB2 (04-15-2019)
#37
Get a different shop compare VIN numbers and make sure they match. There is one stamped on the engine block, one on dash and there are couple other hard-to-get to places. If they all match, then it is what it is. Document this.
A unicorn, one of a kind car that is probably collectable, or you are a victim of a scam.
#38
Yes, it is a model year 2016, but apparently built in 2014 as a pre-production-cycle road tester.
AJB2 (04-15-2019)
#39
#40
AJB2 (04-15-2019)
