Issues at high speed
Hey guys , I have a 2016 ftype R with velocity ap downpipes , pulleys , tune , transmission tune , and mina gallery intake installed. I have been having some type of hesitation around 130+mph and was curious if anyone else had this issue or have an idea what it could be . Car runs fine all the way until 130+mph. Was thinking of doing datalog , what should I look for ?
Assuming you have good coils and plugs currently, may just need the cooler plugs and smaller gap to prevent pre-detonation and handle additional pressures on the spark gap. I have similar upgrades and maybe a few others, and I put cooler plugs and it runs really well with no issues.
Good luck.
DC
The following 3 users liked this post by Therock88:
NGK 96024 Iridium Spark Plugs Heat Range 8 - Gapped to .036
And my DIY here if you want to do it yourself.
CLICK HERE
I had a similar issue with my 997 TT after adding about 100 HP and the plugs cleared it up. It was sputtering in the mid-range.
Good luck.
DC
One thought would be plugs/coils, given the hesitation. With the mods you listed, you have effectively created an increase in boost and power pretty significantly. Typically at this level of increase, you would want to go with 1 heat range cooler Iridium plugs and gap them down to .~036.
Good luck.
DC
Good luck.
DC
Try the ones in my signature - These:
CLICK HERE
Good luck.
DC
CLICK HERE
Good luck.
DC
Im about to hit 60k so I needa change em out anyways especially with the way I push the car a lot. Wouldn't hurt , also not 4th gear more like 6-7th gear I believe , it's always around 134+mph and it happens I'd say mid range rpm
It happens in whatever gear im in around 130ish.
If it occurs at 130mph regardless of gear, it can't be engine related. Sounds like it's transmission related.
I changed my plugs to ngk and gapped em to what's recommended and put brand new OEM coils and issue is still happening . I talked to VAP and they said they never heard of a issue like this , my car runs perfectly fine until it hits 130+mph . Not sure what it could be
I've had this issue for a while when I had my viezu tune. Viezu couldn't figure it out so they just dumped boost on the top end of the rpms to stop it from happening. Told vap about the issue, and ended up buying their tune. It's an issue in the tune that they need to turn off in the tuning for overheating cats if I'm not mistaken. Let me guess. You can do a pull the first time and it pulls great with no issue. Then the next time you try there is hesitation on the top end? I ran behind the issue for a year with viezu, changed out damn near everything. And still had the issue. It was in the tuning all along. There is a video on YouTube about it from skrrrt garage. He had the same issue, and vap fixed it for him.
Good luck
Andi
RacerX
11-01-2019 12:37 AM
