Its about the spare, or the lack thereof
#41
Received 3,209 Likes
So I just checked my F-Type, and I only have one tow hook - the black one!!!!
The Owner's Manual says, quote: "The front towing eye is located in the luggage compartment, along the right side of the vehicle's battery", but I checked and nada, zip, zilch, I definitely do not have the front ("silver") tow hook.
On my XFR I have only the (silver) front tow hook and not the (black) rear one.
So what gives?
Also, why is it wrong to use the rear tow hook?
I would have thought that on a rear wheel drive car, especially one with an LSD, it was best to tow from the rear with the rear wheels off the ground.
Or is it best to tow from the front because towing from the rear will cause problems with dragging front tyres due to the steering being locked?
Confuzzled!!!
#42
#43
Yep, I've read this before, and also that the rear tow hook should not be used and only the front tow hook should be used.
So what gives?
Confuzzled!!!
So what gives?
Confuzzled!!!
#44
#45
I know this thread was originally about spares but since it has brought up the topic of tow hooks I have a question. On my 2016 R the tow hook that threads into the front port does not thread into the rear port. The thread opening in the rear is a smaller diameter. Are they all this way?
#46
Yes, they are all that way, so you can't use the wrong hook in the wrong hole. As explained elsewhere the smaller black rear tow hook is not meant to be used and the dealership is supposed to remove it from the car as part of the pre-delivery service, but many forget to do this. Which is why I am mystified that my car came with only the small black one!
OzXFR (03-13-2017)
#47
Just out of curiosity I tried the XFR front tow hook on the F-Type, and it fits perfectly! So for now I have moved it over to the F-Type, and no need to take you up on your offer. Anyway, there is a seller in Lithuania of all places advertising an XF front tow hook on eBay for a fairly cheap price, including postage probably less than what it would cost in postage for your spare one.
#48
#49
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/spare_tire_a5d3a68f2ab226a62741fe00d06cf6e9a2257cb6.jpg)
Jaguar F-Type Coupe spare tire
At the dealer, deciding between the Convertible and the Coupe the salesman takes my wife around the back, opens the boots and says "Missus Simon, check this out". My wife sees the small boot on the Convertible and exclaims "you have to buy the coupe" so I did. I ordered the spare and she was not happy, "what happened to the trunk?" I told her that was "demo mode" and this was "real world."
We've taken 1- week road trips with the cover removed and the spare in place without a problem and it saves $ cutting down the souvenirs you can fit.
#50
#51
Just purchased 4 Michelin Sport 4S from Costco. Their "Tire Care Recommendations" on the reverse of the invoice says " Fix-a-flat" products should not be used. These products void some manufacturer warranties. Costco will not perform tire repairs on tires where Fix-a-flat has been used."
Drat: fix-a-flat appears to void the Costco "Road Hazard Failure" warranty - and likely even Jag branded gooo falls into this category. Is it that they don't want to "mess" with gooey repairs, or is there a real technical reason for this? What happens if we use a plug on the road? Will/should a tire shop replace it with a permanent plug?
Michelin does not have a road hazard failure warranty, so that's not an issue.
Desert Hiker
Desert Hiker
#52
It's the former. ....again, I wouldn't worry about flats, particularly on a car that (in my case) never sees bad roads. I can't recall the last flat I've gotten in the past 35 yrs
funny thing is that I'm also a member on several dual sport motorcycle forums where guys are trying to switch from tubed tires to tubeless so they can use plugs and goop......the difference is that when you are 100 miles from civilization and out of cell range, you need to have a system to fix flats. Since I don't use the Jag to hunt out remote fishing lakes, I'm not going to worrry about getting a flat tire and if I do, I'd guess that the goop Jag supplies will fix it most of the time. .....If I was really worried, I'd carry a plug kit too.....but there is no way I'd bother with a spare.
Dave
Dave
#53
Dave, I don't think the quality of the road is the determining factor in the desirability of a spare. I had a tire disintegrate/separate on I-5 between SF and LA. As fine a road as exists in the US, and another time I hit something on the road that put a hole the size of a silver dollar while on I-10 outside Van Horn TX.
I would never undertake a cross country trip in my F because I only have the goo and the compressor, If I had a temporary spare and some way to hold onto the full size wheel I might. There are just too many long, long stretches in the American West without any services. West Texas might as well be the back side of the moon.
#54
#55
Agreed. We all have our own assessment formula and data base not to mention risk tolerance. But let's say you are 20 miles outside Van Horn TX and 500 miles from home with an unrepairable flat. First you need to get a flat bed to come get you. From my experience that's three hours (and 70 miles distant), then you need a motel and a rental car because it's going to take two or three days to get a Michelin SS 275/35-19 to you from LA or Dallas. In my case I was driving a Volvo VR and had installed a full size spare and proceeded home.
#56
TR64ever (05-22-2017)
#57
Tempting to buy "any old 19" but wouldn't it have to be fat (low profile) to fit the rim?
I'm sure it would throw all the sensors fits with a different diameter at the tread, still if it get's you home, I'd consider fitting a "throw away" tire to get me home.
Could some of our tire experts weigh in on what sizes of 19" (or 20" for those with 20" rims) would work -- or at least establish boundaries on what works and what doesn't.
#58
I have a couple of dual sport bikes that I ride offroad. They are simple bikes that I can easily repair almost any issue. On a remote ride, I carry spare tubes, air pump, patch kit, clutch cable, tire irons, wire, fuses, tape, mechanics wire, spare fasteners, spare bulbs, extra master link, a tool kit and more.......I know that if I have a problem or failure that I need to be able to fix it in order to get home.
The F type? as I said; flat repair goop, plug kit, compressor, cell phone and credit cards seem appropriate to me.
Cheers,
Dave
#59
#60
Dave
