Its almost winter time- need some shoes for the R - will these fit?
Hi All - woke up to a morning in the 30s here in New England, realized I need to get a move on with finding a winter wheel/tire setup for my '17R. I already decided on new 19" Conti DWS 06 tires (used the same tires with my S4 in the winter with awesome results).
My first preference would have been to find a set of 19" propellers but I haven't had any luck so am looking at a set of Coventry Ashford wheels 19x 9.5 (et35) for the rear and 19x8.5 (et25) for the front. They are rotary forged and I've had a set of rotary forged wheels previously from TSW (who own coventry I believe) that I liked.
I can't see any reason that these won't fit on the R as I dont have the ceramic brakes BUT my local tuner, who I trust and respect, tells me that (according to Coventry) they will NOT fit on the R, even with standard brakes. He can't explain why, so I wonder if his information is incorrect.
Does anyone have any experience putting these 19" wheels (link below) onto an R, and/or if anyone else on the forum has purchased 19" wheels for their R with positive results please could you share details? I've seen the 19" winter wheel/tire packages for the SVR on Tire Rack but dont recognize any of the brands.
Fitment | Coventry Jaguar Wheels
Thanks in advance for any help and advice!
Not sure about THOSE wheels, but I recently struggled to find winter wheel options and ended up finding quite a few good ones.
I ended up with some 19" wheels from TireRack for my 2015 V8R Coupe. If you look at the wheels that they list as fitting the SVR, there are quite a few options...I ordered the Axis XR 19x8.5 wheels listed for SVRs for my winter wheels w/ the Perelli snow tires on them. They have fit just fine on my car which does not have the ceramic brakes (I'm pretty sure they wouldn't fit over ceramic brakes). Here's a pic showing brake caliper clearance.
I have been told that the reason TireRack has SVR options there is that they had an SVR stop in and get measured, but they aren't sure if that means it fits other F-Types. I am giving them at least my experience as feedback, so maybe these will start showing up as F-Type R options for wheels on their pages. If you do decide to look at TireRack, ask for Luke. I worked with him and he was very helpful. His extension there is x4362.
Do you plan to drive when it starts to snow? That's the only reason I think you would want to put dedicated winter tires on.
I live in CT and have driven through the past 3 winters with the awful P Zero's right up until the time it starts to snow / they grit the roads - the car stays in the garage on those days. Was definitely manageable if you are sensible.
Here's my setup: 19" OEM Propeller staggered setup w/DWS06.
Check out my aggressive spacer specs! You think too aggressive?!?!?
j/k I was just too lazy to bolt up and wanted to visualize how they would look in person. I might play around with black plastidip--have a can around somewhere, although I'm not too crazy about the murdered-out all blacked out look, but who knows. BTW, they look better than my Rotor wheels
I threw them on the car to check clearances and then took them off again because the weather is still good. This is just a quick snap of when they were on the car in the garage. I'll get some beauty shots later.
Did you buy the propellers from a dealer or find a set second-hand? They are definitely my first choice. The reason I was looking at the Coventry's is that apparently they are made specifically for Jags, and they are also rotary forged - I have had a set of rotary forged TSWs before and I liked them. They are listed on their site to fit the S, but not the R, but I'm not aware of any differences in the brakes/calipers or fitment between the two, unless you have the CCs...
LOOL that is awesome - Please tell me where I can get those spacers! Who doesn't love the micro-machine hotwheels look!! Jk. I would normally have said black em out but the contrast actually looks quite nice..do you know what the offsets are on those?
I bought mine as take offs from a fellow member here.
These look legit and I have no affiliation with the seller. But if you do end up getting them from him, please PM beforehand b/c I'm eyeing another different setup from him and this could possibly work to our advantage--or at the very least, you get the wheels you want.
19" JAGUAR F TYPE REAR PROPELLER WHEEL 59906 TAKE-OFF | eBay
Propeller offset is 49 front and 27 rear.
I love my Continental Ultra-High Performance All-Season DWS06's so much that I never swap out of them...and why my OEM wheels and tires are "racked."
I have an almost brand new set of OEM Propeller Wheels stored in my garage - with slightly used OEM Pirellis still on them - covered and on a rack, which I'm not sure what to do with (or just keep them for if and when I need new wheels or to replace a wheel). In other words, I might be amiable to selling them...
I have Coventry 19" wheels that fit my 15 F typeR.. they are a few years old now as I had them for my XKR and now use them on my XE sport. Decided to take the FtypeR to Florida this year so don't need snows on it.
The tires are the snows with 'walnut technology' (don't remember the brand) and they are really good ... lots of good snow tire choices available.
Lawrence
Lawrence
Lawrence
Lawrence
I never did put them on the F type R as I parked it instead, however the master mechanic at my dealer had told me they would definately fit my 2015 as the pattern etc. would be the same as my XKR.
I will see about sending a picture... by the way, they are sized to the fronts (all 4) as wide rear snows do 'snow plane' more, or at least around here due to heavy snow.
Lawrence
shahuk (10-20-2017)
