J-Blade Running Lights
Lights on the front of the car can be white or yellow only. Lights on the rear can be yellow or red only (with the obvious exception of the reverse lights). This includes things like under lights.
Short version: Red means rear end of the car. You wouldn't want to make people confuse the front of your car with the rear.
Some states have their own restrictions, my state laws only limit front facing lights to four and requires red or amber tailights.
547.305. RESTRICTIONS ON USE OF LIGHTS
- (c) Except as expressly authorized by law, a person may not operate or move equipment or a vehicle, other than a police vehicle, with a lamp or device that displays a red light visible from directly in front of the center of the equipment or vehicle.
- (c) A person may not operate a motor vehicle equipped with a red, white, or blue beacon, flashing, or alternating light unless the equipment is: 1) used as specifically authorized by this chapter; or 2) a running lamp, headlamp, taillamp, backup lamp, or turn signal lamp that is used as authorized by law.
You can hundo p change those lights. Just like marker lights that are supposedly required on ALL vehicles by DOT, a ton of vehicles don't have them and cops really don't give 2 *****. Plus, when your actual headlights are one, the DRLs are not. So it's not going to cause any confusion at night where it could be a problem due to low visibility and it sure ain't gonna cause an issue during the day
I wish the cars in the UK understood that - lots over here run their super-bright DRLs all the time. And what are "cornering lights" all about? Why do they come on during daylight - presumably drivers can't see corners when it's not dark?
They play more and more with this combined daylight, cornering lights. My wifes car, a T-Roc, has this lights all around the air inlets in front. So they are not always combined with the headlights. And I agree that they should adapt to the ambient light, as they are mostly very bright in clouded conditions.
Is a cornering light like a turn signal? You folks across the pond have some weird terms haha. Anyway, to the OP, I'm definitely interested to see how this turns out. It seems like a giant PITA to pull the headlight apart and I know each headlight is 3 grand, so be careful!
No, it doesn't wink, just looks like you're a loser using half your fog lights when there's no fog. Jaguar did it much better in my 2010 XKR - bulb embedded in the headlamp unit and it only came on if the headlights were on. Still not very useful, though.
