Jaguar 24-Hour Roadside Assistance
It might sound lame (on my part) but early in the drive to work this morning - 30 miles - my left rear tire displayed a low pressure indicator (31 instead of 36) and while I intended to stop off to top off, I just never had the chance.
I made it back home easily enough without any problems and decided to give the roadside assistance program a try.
20 minutes after my call a tow truck showed up with a pleasant fellow - naturally wowed by the car - who cleanly and professionally pumped exactly 5psi in the rear and I promptly gave him a fin to buy himself a beer (that's the idea anyway).
I received an automated call from Jaguar asking "if my issue was resolved and how long ago did the driver arrive". That was followed, minutes ago, by an actual person asking me if it was resolved and to my satisfaction.
Indeed it was Jaguar, indeed it was. Thanks!
BierNut (09-15-2015)
Either way, good to hear they were on the ball.
Quick answer buick is no and yes. I used to have a portable air pump (from one of my NSX's) but don't know where it is. And while I have several places where I could have rather easily stopped by to or from work for air I just didn't find the time to do it. I also have AAA but, as you suggest, I thought I would give Jaguar roadside assistance a shot/test. It couldn't have been a simpler task but I'm happy to report this simple "fix" went off without a hitch.
buickfunnycar.com (09-15-2015)
Thanks for the reminder.
If you had the same tire twice, I'm betting you picked up a nail. You might want to have it checked out when convenient. Been there; done that.
Meanwhile, I've used the little pump that came with the car -- not actually on the Jag, but on the wife's Lexus when we were away from home at the beach. Worked fine and even has a integrated pressure gauge. I don't recall there being any pieces that could be missing, both hose and power cord are permanently attached.
[re] the pump. I remember taking it out and while it's certainly not rocket science I think I glanced at the diagram on the pump itself (although it might have been the case it came in) and it appeared that it was missing some sort of canister? I was pressed for time that day and took the path of least resistance; stopping in a local, trusted, tire shop.
Thank you for the reply.
Best regards,
Jay
Makes sense, good idea, and I think we've all been there at some point or another. Will check first chance I get. (Curious though that the first time I got the low pressure indicator was probably over a month ago and I've since driven many many (including spirited) miles. You would think a nail - and a slow leak - would have shown signs of that long before?
Best regards,
Jay
Best regards,
Jay
You can buy a valve stem tool for less than $10 at a car parts store, which is like a small screwdriver that fits over the stem, and allows you to tighten it. That's probably the number #1 cause of slow leaks.
Jay, those are exactly the signs of a nail that may have just barely punctured the interior cord, or even more likely, a loose or bad valve stem. You should not be losing 5 psi/month unless the temps drop from 80ºF to below 30ºF during that period.
You can buy a valve stem tool for less than $10 at a car parts store,v which is like a small screwdriver that fits over the stem, and allows you to tighten it. That's probably the number #1 cause of slow leaks.
My Audi A8L had a value stem issue just last month and your suggestion is, as usual, a good one. Will check it out with thanks.
Best regards,
Jay
Best regards,
Jay
F-TypeRookie (09-19-2015)
Will check that out first thing in the morning buddy and report back.
Thanks!
Jay
P.S. What's a yute?
![Icon Lurk5](https://www.jaguarforums.com/forum/images/smilies/icon_lurk5.gif)
Vinny Gambini:
Your Honor, may I have permission to treat Ms. Vito as a hostile witness?
Mona Lisa Vito:
You think I'm hostile now, wait 'til you see me tonight.
![Icon Crackup](https://www.jaguarforums.com/forum/images/smilies/icon_crackup.gif)
By the way you can also use any third party truck tow service in Covington for your jaguar. They are also reliable to use and i think they less as compared to others.
