Jaguar F Type ABS problem
Hi. I have a friend who went through a pothole. The car is a 2016 UK.
This was on the left hand side, which broke the control arms allowing the wheel to smash the ABS pump (back casing broken open and circuit board cracked), along with destroying the font bumper, side skirt, left wing, arch liner, pedestrian impact system and pre-tensioner.
The majority of the parts have now been replaced (pedestrian impact system and pre-tensioner left to do), however, the car won't start.
I got hold of a copy of SDD and scanned the car. The non starting seems to be associated with the steering column lock, B100D-64, however, I am fairly sure this is linked the the ABS as this will not scan (see attachment).
The ABS pump was second hand (marked as working) and is the exact same part number. From what I read it does not need programmed, however, as it won't connect anyway its not possible.
There is no sign of wiring damage and the ABS fuse is ok, however, as there is a load of modules not showing I assume I am missing somthing.
Any ideas what to look for would be appreciated, as I feel close to petrol and a match.
Carbuff2 (06-14-2024)
