Jaguar F-Type Coupe Front Bumper Tow Hook Eye Cap Cover
Received 3,209 Likes
The cover has a little plastic tether about 2 cm long on the inside of the bottom left corner and it is integral to the cover (ie moulded into it).
The end of the tether has a triangular shaped "hook" that goes through a slot in the bottom left corner (looking at the bumper) of the opening, then once inserted through that slot the only way to get it out again (without breaking it!) would be to wiggle and manipulate the "hook" out of the slot.
I can see that slot in your pic.
I didn't try getting mine out as I didn't want to accidentally break the flimsy looking tether, I just wiggled it around a little to get a good look at it and see how it works.
The part you want is part # T2R2870, part # 10 on this page: https://parts.jaguarpalmbeach.com/a/...S/4760010.html
Edit - forgot to add, that little tether is not what holds the cover in place, it's only there to stop the cover falling off completely or getting lost. The cover is held on by two simple clips on one side and a tab on the other side, gently pushed on from the outside, so you don't really need the tether at all to fit the cover.
osopolar (04-02-2022)
Vegaskid
09-20-2021 08:48 AM
