Jaguar F type V6 Coupe 340hp with or without active exhaust?
Hello Guys, my 2016 jaguar F type V6 340hp, doesn’t have the switchable exhaust button option. But I was wondering how can I know if I have or not the active exhaust option?
I only know that my F type sound really loud and produce a lot of crackles being completely stock from the time I picked it up new from the jaguar dealership.
Does an active exhaust system mean that you get exhaust valves that open at higher rpm without being able to control it if you don’t have the switch button or simply that you get louder exhaust notes?
I posted 2 videos that show the sound of the car
Thank you for your answer
If you have active exhaust but no switch and want to make it louder all the time, you can pull fuse #43 (under the passenger footwell) which will permanently disabled the valves and leave them open all the time so the car will be louder all the time. If you don't have a fuse #43 there, then it is fuse #15 under the hood. Absolutely no other issues or changes if you pull the fuse--no warning lights, no change in performance, etc. Just more volume--it's like getting a free upgraded exhaust system!
This is correct. There is 'active exhaust' and then 'switchable active exhaust.' On a base car, you can actually have three exhaust setups: a standard exhaust (no valves), active exhaust (valves), or switchable active exhaust (valves and switch). Since you don't have the switch, you either have standard or active. Easiest way to tell is to look under the car at the muffler and see if there is a valve connected to each side. No valves means standard exhaust. You should also be able to hear an audible difference when you switch into Dynamic mode.
In my case I was thinking maybe in the later 2016/2017 models before the OPF, the sound was way more present, and the best case scenario when not having the switchable exhaust button was not having the active exhaust system because it doesn’t let us hear the car independently.
Here’s how active exhaust works. You can look at the exhaust to see if the valves are present.
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
Note that around MY16, they deleted the electric vacuum pump and replaced it with a vacuum line coming back from the engine.
Received 3,209 Likes
