Jaguar f type v6 Turbo swap
DPelletier (06-10-2021)
Power that is lost early will be made up later. Not to mention rwd v6 has trouble putting down power off the line
"but also should factor in losses and max Airflow / boost when comparing them" this mostly.
Compare how much air a big *** twin screw can flow vs say a little garret t25 or, conversely, how much air a turbo from a diesel container ship flows vs a stock blower from a v6 F-type.
Thing is, the supercharger isn't the limiting factor here. It's almost always the bottom end. They're already comparatively high compression motors (for a boosted one at least), and w/ a tune/pulley are already pushing like 2 bar of boost. Pushing it much past that and you're gonna end up eating your piston rings for breakfast or putting a conrod through your block.
You could probably do some sort of custom af set of internals that will hold up to the power and build yourself a crazy 1000+ hp monster.. but the truth is, if you were gonna do some sort of crazy off-the-wall build for a ftype v6, the source of the boost (sc or turbo) would mostly be a matter of preference / what fits under the hood. Then again if you've got the scratch for that, you could probably just buy yourself a nice V8 F-type, modestly tune it to 660hp/630tq, and save yourself a lot of money/headaches. Hell even for a v6 it'd probably be significantly easier and cheaper to swap a used V8 and tune it than do some crazy full-race rebuild and custom turbo setup / block / engine management etc for the v6.
All that being said.. I'd be stoked to see it if you actually were serious. I love seeing people do way over the top, completely beyond reason builds. I've wasted money on dumber stuff than that before.. so I get it. Just know that it's a lot more involved than replacing the blower w/ a snail.
V6 has a TVS1320... which I wouldn’t call a big *** twin screw.
- if you look at the efficiency graph for the TVS 1320, apply it to conditions were you would be racing, you would see why I say that. It IS a limiting factor when it comes to v6 hp.
A member on this forum has had a v6 tested. Stock can hold 600+ (maybe he said 670?)
The examples were just to illustrate that there are a wide range of both SCs and turbos, and ultimately they'll both work as long as they're spec'd for the application.
Not blowing up on a dyno pass ≠ track days full of abuse / daily driving / etc
220hp/liter is a lot to be asking of any stock engine, but again.. I've done dumber stuff than that.. and I'd be stoked to see ppl try.
SinF (06-06-2021)
It is important that we keep things in context. My posts are related specifically to the aj126... 3.0L v6 f type. Bringing in outlandish examples doesn’t really add much to the discussion.
As far as doing a turbo swap I think you are correct that a twin turbo set up would probably be able to produce more power than a supercharger since a supercharger has much larger parasitic power losses. It would be interesting to see how you would stuff such a set up under the hood with the required turbos, piping and intercooler
SinF (06-06-2021)
I think the member you are referring to is Ftype17. I am pretty sure I remember that when he built the big V6 he beefed up the bottom end of the motor to accommodate the increased power. Also I seem to remember a discussion about the forced induction limits of an open deck motor which both the V6 and V8 are.
Fitting it all under the hood seems like the tricky part
